virus that says you must pay police £100?
18 Oct 2002
Newcastle, England
Has anyone had this? how do you remove it? my girlfriends friend was doing nothing more than playing scrabble and she got the thing, how do you fix?
I had this a few months ago. Lots of sites said to boot into safe mode and remove it using AV, but that had no effect on me, the virus still blocked my pc in safe mode.
Managed to get rid of it by running a windows restore point from that morning.
Boot to safe mode with networking. Download Malwarebytes, update definitions & perform a full system scan.
Boot into safe mode w/networking.
the threat itseld will be a randomly named .exe normally in the user profile folders.
just sort by date modifeied or even search for a *.exe created within the last few days in the folder. Permanantly Delete and reboot.
Sorted
Use a 'Combo Fix' which will rip it from your system but may damage a few reg files but it will work.
Not come across any like this that have been more than a random exe in user profile folder.
You do know there are varients of this floating about? Some can't be removed because they hide regardless of what you use and some varients require a format. Doesn't matter if you restore, remove or whatever you do.
There are only so many places where malware can hide. Even nasty root kits can be removed with a little effort. It depends how much effort one wants to put in to remove the infection. Format is always the easy way out. :)
Regardless of what you use?
Please tell me you're not just going to safe mode and running random scans in the vain hope one of them has been updated recently/correctly in order to pickup one of these varients you speak of?
I've seen people say they've used all sorts to no avail only to manually check thru the folders and locate the problem in a short period of time.
BOOM
Nail|Head
Got rid of this for a colleague. It was a single exe file running from the registry. Easiest way is to boot from a boot disc (Hirens etc.) and then just delete the file.
If it were me I'd take everything important off the machine and re-install, you can never fully guarantee that the system is clean and that it hasn't downloaded itself elsewhere or hooked onto something else.
I cleared this on a work laptop a few weeks back. Its profile specific. I logged in as admin and ran Malwarebytes. This detected and removed it.
