Ranking / pro's and con's android phones
31 Oct 2012
I was all set for the Nexus 4 but after a frustrating attempt (well countless attempts!) to purchase I am wondering whether to choose another option?
Whatever I go for will be big upgrade (Wildfire!!).
My plan was to go for the Nexus 4 with GiffGaff so had that sort of budget in mind.
I am with Tmobile and can do early upgrade in December or wait til February and consider all networks.
I use phone for browsing mainly (loads) diary, astrid, email, football score etc, music, sky news, bbc news clips, gmail. Not really into gaming and sure any current camera will do me.
Trouble is had worked out budget based on N4 so don't want the 2 year costs far away from that.
I can compare specs but wondered summary of views for ease of use, speed, browsing, typing organisation tasks etc
How do users think the following would be for me, what screen size do people prefer?
S2
Note
N4
S3
Note 2
Think the S3 and Note 2 probably will be too expensive.
Very grateful for personal experiences and advice.
Thanks
I think your best option is to go to a store and see if the note/note II's size is too big or just right for you.
If you like it, then go for it, if you feel it's too big, then you've crossed 2 phones off your list.
Are you not considering HTC One X+?
Thanks for the reply. I had forgotten about the HTC One x - but only person I knew with it said had a terrible battery - not sure if that is fair?!
I tried the note 2 (shop I visited didn't have note). Thought it seemed great for demo when you are really examining it - not so sure about real life. Interested in how people find them after few weeks of use?
Guess key part of my dilemma... for browsing, email, task management and sky news etc - would I notice the benefits of the better specs of S3/Note2 etc over S2 and note? Do few more pixels make much difference.
Or are these increased specs only really beneficial if heavy gaming or watching movies?
Wait for the N4, It truly sets a new standard in terms of speed and performance. I never really seen anything faster, not the Note II or the iPhone 5 or anything from wp. All that plus it looks really really nice (Personally), and feels really well made and solid. Only thing I would change is stick the One X screen on it, just love that floating look. If you can wait then just sit back, at £279 you wont get anything better.
The One X+ has a larger battery so the battery life should be improved, I personally dislike sense but the phone has amazing build and display. It also has larger storage.
If you can wait get the N4, its has great hardware, nice build, its cheap and its surprisingly light and feels good in 1 hand, comparing it to my S2 and it felt much the same.
And there is the one XL ;)
With jellybean running on all phones, I doubt you will see a huge difference in speed and smoothness across the note II, GS 3, one X/X+/XL, S4 powered handsets will feel more snappy and instant when loading apps, game levels, gallery thumbnails etc. due to a number of reasons such as having way more performance per core than the exynos quad core (android and apps don't fully utilise dual core let alone quad yet so the greater performance per core is more of a benefit than an additional 2 cores amongst other reasons)
Battery life wise, the one X+ and XL are very good (X+ seems to have a problem at the minute with drain whilst idle, but am sure that will be fixed soon.....). None will be anywhere near the note II levels though.
Jellybean has improved the one X as well in a number of areas including battery life (although won't be as good as the X+ and XL), the performance is even better than the GS 3 running JB surprisingly (in benchmarks) :eek:
Posted some pros and cons of the phones in another thread:
Instead of the one X, I would look at the X+ (bigger battery, better front camera, 64GB internal storage and has JB/sense V4+) or XL (LTE support, better CPU thus better performance and battery life) instead.
If you are sure that size isn't an issue, then the note II, if it is then I would decide between the X+ and XL.
Main advantages of the note II (some apply to the GS 3 as well) over the X+ and XL is:
- battery life
- screen size
- 1080P recording
- SPEN
- 2GB RAM
- better CPU chipset than the X+
- NLED
- SD slot
Main advantages of the X+ and XL over the note II:
- screen quality
- build/perceived quality
- X+ has 64GB internal storage (XL is only 32GB), both have no SD slot
- XL has the better CPU chipset
audio is more or less the same, design is personal preference and software skin is personal preference.
The camera for photo quality is more or less the same on all the phones, some shots look better on the note II whilst other shots look better on the X+/XL, both have plenty of features/options (hopefully the GS 3 will get some of the camera/gallery features from the version of touchwiz on the note II), but one series/sense has more stuff overall and the camera UI is better (IMO)
Screen is also personal preference, but many people and review sites still class the SLCD 2 IPS screen as being king, but many people prefer the SAMOLED panels due to blacks, infinite contrast ratio, vibrant colours so games and videos look amazing.
I personally wouldn't bother with the GS 2 or note now.
Best to have a play with them for yourself and see which one you prefer.
If it where me and size wasn't an issue and you don't mind touchwiz, then the note II, if size is an issue and/or you don't like touchwiz and you don't need more than 32GB internal storage then the one XL, if storage is an issue then the X+
The one S is another alternative, for some people, the downsides of it compared to the X+, XL are:
- screen isn't 720P and not as big but is still superb overall, don't let all the pentile talk put you of, judge yourself in some shop but not beside the XL/X/X+ as it will look pretty poor then :p The only thing I want is a bigger screen :p
- 16GB internal storage (10GB for videos, photos etc. and 2.21GB for apps)
- crap NLED
Everything else is as good as the X/XL and in some areas better i.e.
- CPU chipset same as the XL, so superb and second best to the the S4 pro in the N4
- audio is amazing, second best to the GS 3, although some say the one S audio sounds better, doubt there will be much difference though
- camera same as the X/XL/X+, however, 1080P videos look much better in terms of smoothness and light metering
- aluminium uni-body, which IMO feels far nicer than all the phones especially the black model which has been micro arc oxidised (but some people have had chipping issues with it, however, HTC released an updated design with smoother edges that has fixed the problem, the grey model doesn't have any problems)
- battery life is amazing, only beaten comfortably by the note II, slightly better than the GS 3 and way better than X on ICS (need to see more battery stuff when more people get JB). Plus if you really want you could fit the 2100mAh from the one X+ into the phone :p ;)
However, there are 2 models floating around, 1 with a S3 chipset (old gen) and nowhere as good as the S4 chipset, mainly in the performance and power efficiency areas. S3 CPU has a clock speed of 1.7GHz and S4 CPU has a clock speed of 1.5GHz.
Regarding screen size, the bigger the better IMO, however, only if the phone is comfortable to hold and easy enough to use with one hand so no bigger than the HTC DNA for me. The GS 3 is very comfortable in one hand (still not the easiest to navigate the entire screen with one hand though) compared to the X/X+/XL despite being slightly larger.
thanks, some really useful - albeit contradictorary! replies.
Think if I knew that I could guarantee N4 in x weeks time at the launch price it would be easier. I fear the supply contract free may just be a trickle and so a lottery, or prices will rise.
Go from being greedy and wanting the best spec to remembering my use would not fully stretch a modern phone and don't need the latest gadget...guess which is likely to win!
be careful when considering the htx one XL. Cnet uk states that our version has a lower screen res than the original one x.
a few failed N4 link buyers looking for advise!
users / those more technical - appreciate your thoughts please
Just wait for a cheap Nexus 4. Nothing comes close for the price, performance and software support...
Find another toy to play around with until there's plenty of stock.
CNET got that wrong as well as the amount of internal storage (iirc they said 16gb but it has 32gb), some guy in the x thread got one.
if you cant wait for n4, then the s3 is available for £350 and that would be your next best option in terms of price/performance.
happy to wait IF;
1) will be enouth stock that I don't waste another day trying and failing and can confidently buy one - don't mind if not for few weeks
2) price will be launch price...or lower!
As I don't make many calls and am willing to put the cost of a Nexus down as initial payment, a Note 2 looks possibly in my price range - may try to visit CPW today for a play.
happy to wait IF;
The google price wont change, it just a matter of waiting. I really cant recommend anything else when you look at the price and as long as you willing to wait for more stock it should be okay. If you need something right away then thats different.
Maybe will be less tempted to go for a note 2 or similar, and more patient if I stop checking playstore and here everyday!
If I am staying with Tmobile, don't want any fees and the discounted deal they have promised me then I have until 20 December to make my mind up.
If I get N4 before then then will use Tmobile until end of contract then switch to GiffGaff.
If the N4 is not available by 20 December not sure I will have the will power to turn down a galaxy 3, Note, Note 2 or similar HTCs!!
