- 10 Sep 2008
There isnt always a "correct" answer.
Won't correctly replacing all defective parts always be the correct answer?
I don't quite understand how garages get away with saying "we think its this, it'll cost £xxx, do you want us to do it?" - Yes, after all your the mechanic. But can then say "No thats not fixed it, we think its this, it'll be £xxx, do you want us to do it?..... and so on. It feels like they fix the entire car by replacing every part until randomly reaching the real problem. But it doesn't matter to the garage as your paying the parts and labour.
In my (unrealistic) opinion I think that if things they do to fix the car don't work they should remove the parts and put the originals back at no expence to the customer, maybe then they'd get a bit better at diagnosing what the problem really is.
