Kingston hyprex 2x4gb ram has one of mem has died...
IC3
IC3
3 Dec 2011
Hi, today I wanted to turn on my pc but it didnt turn on so i opend the case tried to boot it 10 times or more. Nothing than I notice a red light next to memory so I decided to take out one and turn it on, so one of the memories worm and the other 4gb dont work...
pretty sure you should be rma'ing this then, im sure they have a lifetime guarantee from kingston, cannot check at the min as their website is playing up
They do Iv check the ocuk shop and leaflet that came with ram.
Faulty card and now the RAM has died... Such a bad luck...:mad:
I had the same problem. Got a new cpu, mobo and 2 x4gb kingston hyperx. Everything was fine and after a total of 5hrs use the pc shut down and wouldnt boot. Replaced the ram with corsair sticks I had in my old rig and it booted up and is working fine. Have not got round to seeing which stick failed or if it was both, if its only one stick then i'll leave it but if its both then i'll rma.
