This Week Only - 21/11/2012 - 28/11/2012 - Awesome deals on everything PC related!
20 Jul 2009
The bleak North East arm pit of Britain
Hello
We have not had a this week only post in a while so here it is with a brief selection of the deals to be had. :)
Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW) @ £143.99 inc VAT
The Samsung SSD840 is a high performance SSD designed for power users. Capable of delivering up to 98,000 IOPS Random Read Speed and 540MB/s Sequential Read speed, it is an SSD of unrivaled high performance. Even better, the advanced MDX controller delivers these speeds regardless of data type, unlike some competing controllers that greatly favor compressible data.
• Capacity: 250GB
• Sequential Read: 540MB/s
• Sequential Write: 250MB/s
• Random Read (QD32, 4KB): 96,000 IOPS
• Random Write (QD32, 4KB): 62,000 IOPS
• Random Read (QD1, 4KB): 7,900 IOPS
• Random Write (QD1, 4KB): 29,000 IOPS
• Warranty: 3 Year
Was £159.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Gigabyte F2A85X-D3H AMD A85X Chipset (Socket FM2) DDR3 ATX Motherboard @ £61.99 inc VAT
Was £64.99 Inc. VAT
Only £61.99 inc VAT.
ORDER NOW
MSI Z77 MPower Intel Z77 (Socket 1155) DDR3 ATX Motherboard @ £143.99 inc VAT
Was £149.99 Inc. VAT
ORDER NOW
Anidees AI-6B Midi Tower Case - Black @ £89.99 inc VAT
The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior, with a brushed aluminum centre. In between lie a set of stealthy and concealed air vents, which should ensure good cooling.
This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.
Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.
Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.
Dimensions: 207 x 509 x 527 mm (W x H x D)
Material: steel, aluminum
Weight: 11 kg
Color: Black
Form Factor: ATX, Micro ATX, Mini-ITX
Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)
Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)
Top Cooling: 2x 140 / 120 mm (lid, optional)
Filters: Front & Back
Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)
Power Supply: Standard ATX 1x (optional)
Expansion Slots: 8 (without tools)
I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out
Maximum graphics card length: 428 mm
Features: Elements made of brushed aluminum
- Cable Management
HDD and power supply decoupling
- Removable hard disk cages
Was £99.98 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
AMD A4-3400 2.70GHz (Socket FM1) APU Processor (AD3400OJGXBOX) @ £29.99 inc VAT
The AMD Fusion family of Accelerated Processing Units (APUs) is coming. Working in conjunction with the advanced x86 processor cores, an APUs multiple vector cores enable software developers to create innovative new applications that expand usage models and make PCs fast, easy to use, and more intuitive. The recent introduction of new tools for thread-level and data-parallel applications development simplifies the task of creating these applications. The development platforms and tools are scheduled to be widely available. The rest is up to entrepreneurial developers and PC manufacturers.
- Socket FM1
- 1MB Cache
- 2 Cores
- 2700MHz CPU Clock
- 240 Radeon Cores
- 443MHz GPU Clock
- Max DDR3 1600MHz
- Dual Graphics Yes
Was £39.95 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Asus HD 7950 DirectCU II TOP V2 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £257.99 inc VAT
The next generation Asus HD7950-3GD5 graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
- Cranked 100MHz over reference for an ultimate engine clock of 900MHz
- Dual fan DirectCU thermal delivers 20% cooler performance with direct heat dissipation and runs significantly quieter at 600% greater airflow
- GPU Tweak provides a professional yet intuitive graphics tuning interface for real time card adjustment and monitoring
- The latest PCIe 3.0 bus standard delivers improved encoding for twice the performance of current PCIe 2.0
- Expand visual horizon across six displays with AMD Eyefinity technology
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 900MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 1792 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 5000MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 6-pin
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
- All Orders placed on the 22nd October 2012 and after shall recieve FREE copies of FARCRY3, Hitman Absolution, Sleeping Dogs PC Games along with 20% off the latest Medal of Honor WarFighter. This bundle is worth in the region of £100 and is completely FREE (Subject to availability) - You will recieve your gamecode from 2nd November onwards in the email address you provided when placing your order!
Was £269.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Logitech Ultimate Ears 200vi Noise-Isolating Headset (985-000335) @ £15.98 inc VAT
This headset fits your ears-even if they're small-and has on-cord controls. No need to fumble with your iPhone, BlackBerry or iPod. On-cord controls let you take calls, adjust the volume and change tracks on the run. Tuned by the same engineers who make the custom earphones preferred by the world's top touring musicians-for professional sound. With five pairs of soft silicone ear cushions from XXS to L, you won't have to worry about getting the right fit-even if you've got small ears.
Warranty: 2-year limited hardware warranty
• Construction: closed (in-ear)
• Wearing style: binaural
• Connector: 3.5mm
• Cable length: 1.15m
• Weight: 12g
• Special features: volume control
Was £24.99 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
For the rest of the great deals click HERE!
