Are the Corsair Hydro H80i and H100i the same?
Permabanned
19 Jul 2012
Buckinghamshire
I wanted to know which of these would fit in my CM Storm Scout 2 case? Is the H100i better at cooling because of the 2 fans or is the H80i pretty much the same?
Thanks
Yes, but it seems most are working fine after fw update. I really wanted to know if the h100i would fit in my case?
Should I get the H80i then?
I feel there are way too many problems being reported. I know most people only post when they have problems but you don't see people posting problems with air cooler or even other brands of CLC. ;)
H80i are having same fan noise and usb problems.
Some are having problems with usb even with new firmware.
Ok....I will wait a week or two to see if they get better.
I have the H80 and it works perfectly. The H80 has a thicker radiator and two fans for a push-pull air flow. The H100 has a wider radiator with two fans or you can add two more for push-pull.
