**BLACK FRIDAY - SAMSUNG MONITOR DEALS!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
TO celebrate Black Friday were offering some very low pricing on selected Samsung monitor models, check them out:-
Samsung S22B300BS 22" Widescreen LED Monitor - Glossy Black @ £99.95 inc VAT
Experience amazing new levels of colour, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SB300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5000000:1 contrast ratio, the highest level currently available, the SA300 monitor ensures that blacks are at their absolute darkest and (with pristine whites) colours are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colours and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio – and enjoy your multimedia content with the professionalism it deserves.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
- 21.5" (16:9)
- LED Technology
- Resolution: 1920x1080 (True HD)
- Contrast Ratio: Dynamic: Mega DCR (Static: 1000:1)
- Brightness: 250cd/m2
- Response Time: 5ms
- Colour Support: 16.7M
- Input Connection: 1x Analogue & 1x DVI
- Stand type: Simple, tilt function only
- Wall Mount: No
- Set Dimension with Stand (WxHxD): 512 X 385 X 197 mm
- Set Dimension without Stand (WxHxD): 512 X 311 X 53 mm
- Set Weight with Stand: 3.0 kg
- Cables: D-Sub Cable included
- Apple & PC compatible
- 3yr Warranty
Was [119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Samsung S22B300HS 22" Widescreen LED Monitor - Glossy Black @ £99.95 inc VAT
Specification:-
- Screen size: 21.5" (16:9)
- Backlight type: LED
- Contrast ratio: Mega DCR (Static 1000:1)
- Viewing angle: 170/160
- Colour supprt: 16.7M
- Connections: 1x D-Sub, 1x HDMI
- Warranty: 3yr
ORDER NOW
Samsung S24B300HL 23.6" Widescreen LED Monitor - Black @ £119.99 inc VAT
How do you like to watch movies? Do you like lying down on the couch? Sitting in your favorite chair? Cooking or exercising? Whether you’re standing, sitting or lying down, Samsung Magic Angle makes sure that the movie always takes center stage and that you’re always comfortable. This means, thanks to the 5-mode angle management, that whatever angle you watch your Samsung monitor, you will enjoy a full visual experience with amazing picture clarity. So, start seeing your favourite movies and other multimedia in total comfort and without limitations thanks to Magic Angle.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%;, 25%; and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50%; saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
Specification:-
- 23.6" (16 : 9) Screen Size
- LED Type
- 250 cd/m² Brightness
- Mega 8 DCR (Static 1000 : 1) Contrast Ratio
- 1920 x 1080 Resolution
- 5 ms Response Time
- 170° / 160° Viewing Angle (Horizontal / Vertical)
- 16.7 M Color Support
- Inputs: 1x Analogue & 1x HDMI
- High Glossy Black
- Simple Stand Type
- Tilt Stand Function
- 569 x 416 x 197 mm Set Dimension with Stand (W x H x D)
- 569 x 342 x 53 mm Set Dimension without Stand (W x H x D)
- 692 x 415 x 111 mm Package Dimension (W x H x D)
- 3yr Warranty
Was [£149.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Samsung S24B300BS 24" Widescreen LED Monitor - Glossy Black @ £119.99 inc VAT
- Screen Size: 24" (16:9)
- Type: LED
- Contrast Ratio: DCR Mega (Static 1000:1)
- Viewing Angle (Horizontal/Vertical): 170°/160°
- Color Support: 16.7M
- Connectors: DVI & Analogue
- Stand Type: Simple
- Stand Function: Tilt
- Wall Mount: No
- Set Dimension with Stand (WxHxD): 569 X 416 X 197 mm
- Set Dimension without Stand (WxHxD): 569 X 342 X 53 mm
- Set Weight with Stand: 3.4 kg
- Warranty: 3yr
ORDER NOW
Samsung S27B750HS 27" Widescreen LED Monitor - Glossy Black/White @ £209.99 inc VAT
Ls27b750hs has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture.
Features:-
- Screen Size: 27" (16:9)
- Brightness: 300cd/m2
- Response Time: 2ms
- Warranty: 3yr
Was [£259.99] Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
I was hoping for a 27" screen but even at that price (which is amazing) I would rather a CRT... It looks horrendous!
Good deals but I think a 22 inch is too small nowadays for a main screen, gamers should at least get themselves a 24 inch.
Hi there
TO celebrate Black Friday...
You do realise its not something to celebrate? It's a marketing gimmick dreamt up by stores in America and now a trend over here because as research has shown, consumers will only return to a shop if there are regular "deals" to keep them interested.
You mean like OcUK's 'This week/weekend only' deals that they do year round? ;)
