if you are just doing mods you can even leave your PC plugged in at the wall but off at the PSU and just touch the case once in a while to ground yourself
Either that or touch a radiator every now and then.
I find this extremely unlikely... I've been building PC's both personally and professionally for over 15 years and I've never once had a component fail due to ESD from not using an ESD strap...
unless the OP has wool socks and thick pile carpet and a habit of doing the moonwalk constantly while building computers, in which case I suggest you wear shoes or do it barefoot and touch a radiator with your hand once in a while rather than waste money on an ESD strap
why didnt you just get them to send you a 7970 bosted edition lightning for the RMA? gotta be the closest replacement for the lightning and thats what i thought they had to do on a RMA either that or refund.
would have took the 7970 everytime personally.
Tbh the 680 version is probably the better card, dual link dvi and the ability to actually over volt.
I'm leaning towards a 680 as a replacement my self tbh, but I'll likely have another 6 week's of waiting before I can make the call
 I am sure there is a way and someone will find it (ABX is the only way I know of) but deffo more in the tank with these cards than we see.
 I am sure there is a way and someone will find it (ABX is the only way I know of) but deffo more in the tank with these cards than we see.Spoke too soon, new card has been dispatched!!!
Just finished work!! My girlfriend surprised me!! Something was waiting for me
Well green team here I come!!
@gregster I take it, you got one of these babies!! are they easy to overclock on MSI AB
 Both under water and very easy to overclock. Slide the sliders and let me know how you get on. You will need to flash to another BIOS to unlock the +100Mv attribute in AB and only use AB 2.2.3 to use this feature.
