Looking to buy a decent 3 piece suit
20 Sep 2003
Scotland
So with Xmas coming up I wanna buy a really nice 3 piece suit, I'm thinking something really smart, along the lines of what Gary Barlow wears on telly :)
I was thinking House of Fraser but open to suggestions as to where best to go and get a wide selection that you can actually try on.
Cheers
Forget Barlow, you want the Chalky White look...
I bought my last suit from House of Fraser really helpful staff and it was in the sale made by Ted Baker.
Well Im located in Central Scotland with rail access to Edinburgh/Glasgow. Not sure on budget but if it was the right suit then say 400/500?
Find a local tailor - I recently had my first bespoke suit made by a local chap who used to be a senior cutter at Kilgour - it's superb quality and far better than the designer labels, plus you're supporting British craftsmen !
seriously, try TK maxx....they usually have very nice decent brand suits like ted baker / french connection /hawes and curtis / dolce and gabbana etc suits all massively cheaper....then spend some of the money saved getting it altered to fit you PROPERLY...unless you're lucky no off the shelf suit will fit perfectly, so get one kinda close and then take it to a decent tailors, an average suit that fits perfectly will look far better than an ill fitted expensive suit.
http://www.tkmaxx.com/men/suits+shirts/icat/2301
Take a holiday to India....I got a 3 piece suit hand made in 2 days for about £80
Ok you have to pay for the holiday and you will get harrased but 100 screaming kids everywhere you go but still....
