Mobile phones Direct??
31 Oct 2012
After failing with the Nexus 4 plus GiffGaff option I started looking at S3 and Note 2 options.
I hardly use for calls, pretty much browsing, email and personal organising.
The options for a renewal (Tmobile) or other networks looked a huge jump up from my first choice...
then I saw Mobilephonedirect.
Note 2 T mobile, £179 for phone, £15.50 per month, 50 mins, 750mb.
Galaxy S3, £99 for phone, £15.50 per month, 50 mins, 750mb
Not sure will definately stay with Tmobile, or go for this exact deal but looks very cheap.
Anyone used them?
Is it too good to be true?
Thanks
I used them for my HTC Desire two years back, with a plan with Tmobile.
Aren't they just a reseller though. If you propose the same deal with Tmobile I would have thought they will agree to it.
Indeed, part of carphonewarehouse I think. Although they usually give you a sim free handset and a sim only deal. Only downside (if you think it is) is that you won't be eligible for a handset upgrade at the end of your contract.
Not too shabby deals on there. Note II £345 handset cost + 12 * £10 gives you a total outlay of £465. If they are indeed unlocked then you could just use it as a method of buying the phone to then use your current SIM.
