Cleaned the lenses, or wet-sand flatted and polished them?
Properly polishing them will help, but its likely that the reflectors are starting to mar at this age, so likely need replacing.
You're in luck as I only changed both of mine yesterday.
Original Mk1 MX5's (as far as I know) have sealed beam units so you cannot just upgrade the bulbs as the unit is complete.
AFAIK it's only the imports that have sealed beam units.
