- 20 Feb 2009
- Ashton-Under-Lyne
Looking for a CPU cooler of the HTPC build I'm planning.
It's going to be cooling an A6 FM2 chip, in a Silverstone GD05 case, which has a limit of 70mm for the cooler (unless I remove the ODD, which I don't want to do)
I want it to be pretty cheap (under £35 at most) and it needs to be quiet (probably meaning I need a PWM fan on it) but the CPU won't be overclocked at all, so it doesn't need to be amazing at cooling, just sufficient.
Any suggestions?
Any suggestions?
