Celebrating i47 - Gaming Deals!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
To celebrate the fact we are at i47 this weekend I have decided to cut some amazing deals on keyboards and mice!
qpad mk-50 mechanical gaming keyboard - uk layout - blue switches ** free max payne pc game ** @ £64.99 inc vat
nonl2br
<img src="http://www.overclockers.co.uk/lp/productimages/keyboard/blue.gif">
<br>
unlike your average keyboard, that functions through rubber domes, forcing you to press each key all the way down in order for the stroke to register, the mk-50 feature true mechanical switches with unmatched accuracy and feel. no more pressing with full-force in order to activate the keys.the qpad keyboard will respond to your every stroke in an instant.<br>
<br>
other boards normally have a short life span and wear out quickly, resulting in unresponsiveness, delays and a dull, clunky feel to the keys. the key switches on mk-50 are built to last 50 million strokes, and the qpad mechanical key technology provides distinct feedback and puts you in absolute control. the travel distance of the keys is set to 4mm with an actuation point at 2mm.<br>
<br>
for gamers, it’s all about the feel and functionallity and that is where the qpad mk-50 truly shines! with a full size keyboard layout in 3 sections, mechanical key switches, media keys and full n-key roll over, it’s the perfect gaming keyboard. nuff said...<br>
<br>
- key switch:cherry blue mx mechanical switch technology<br>
- n key roll over: full n-key roll over via ps2<br>
- key strokes: 50 million<br>
- connectors: ps/2 or usb (ps/2 to usb adapter included)<br>
- media keys: media keys for volume control, play, pause and skip tracks<br>
- cable: 1.8 meter extra thick cable<br>
- extras: 4 extra orange key caps and key cap puller<br>
- dimensions:keyboard 44,8 x 14,9 x 3,5 cm (17,6 x 5,8 x 1,37 inch)<br>
- wrist pad: 44,8 x 6,6 x 1,7 cm (17,6 x 2,48 x 0,66 inch)<br>
- weight:1.27 kg (2.8 lbs)<br>
- warranty:2 year<br>
- keycaps: removable for easy cleaning<br>
only £64.99 inc vat.
order now
qpad mk-50 mechanical gaming keyboard - uk layout - black switches ** free max payne pc game ** @ £64.99 inc vat
nonl2br
<img src="http://www.overclockers.co.uk/lp/productimages/keyboard/black.gif">
<br>
<br>
<br>
<br>
- key switch:cherry black mx mechanical switch technology<br>
order now
qpad mk-50 mechanical gaming keyboard - uk layout - red switches ** free max payne pc game ** @ £64.99 inc vat
nonl2br
<img src="http://www.overclockers.co.uk/lp/productimages/keyboard/red.gif">
<br>
<br>
<br>
<br>
- key switch:cherry red mx mechanical switch technology<br>
order now
qpad mk-85 red led pro backlit mechanical gaming keyboard - uk layout - black switches ** free wow mists of pandaria pc game ** @ £84.98 inc vat
nonl2br
<br>
unlike your average keyboard, that functions through rubber domes, forcing you to press each key all the way down in order for the stroke to register, the mk-85 feature true mechanical switches with unmatched accuracy and feel. no more pressing with full-force in order to activate the keys.the qpad keyboard will respond to your every stroke in an instant.<br>
<br>
other boards normally have a short life span and wear out quickly, resulting in unresponsiveness, delays and a dull, clunky feel to the keys. the key switches on mk-85 are built to last 50 million strokes, and the qpad mechanical key technology provides distinct feedback and puts you in absolute control. the travel distance of the keys is set to 4mm with an actuation point at 2mm.<br>
<br>
for gamers, it’s all about the feel and functionallity and that is where the qpad mk-85 truly shines. with a full size keyboard layout in 3 sections, gaming profiles, macro recording, mechanical key switches, media keys and full n-key roll over via usb, it’s the perfect gaming keyboard. nuff said...<br>
<br>
- key switch: cherry black mx mechanical switch technology<br>
- n key roll over: full n-key roll over via usb<br>
- lighting: individual led backlight on every key for enhanced visuals<br>
- lighting features: four levels of brigthness allow you to locate keys easily<br>
- connectors: gold plated usb connectors for extremly low latency<br>
- usb hub: two high speed usb 2.0 ports<br>
- audio ports: 3.5mm headphone-out and microphone-in jacks<br>
- cable: 1.8 meter braided cable<br>
- dimensions: keyboard: 44,8 x 14,9 x 3,5 cm (17,6 x 5,8 x 1,37 inch)<br>
- weight: 1.27 kg (2.8 lbs)<br>
- warranty: 2 year<br>
- software: customizable profiles, programmable keys and macro recording<br>
- supports: windows xp, vista, 7<br>
only £84.98 inc vat.
order now
tt esports challenger gamers keyboard @ £24.98 inc vat
this keyboard offers a unique cooling solution for your hands when the heat of the battle takes its toll on you. allowing you to game under many different conditons you will be razor sharp at all times.
- interface: usb
- operational systems: windowsr 7/vista/xp
- number of macro keys: 6
- number of multimedia keys: 7
- 2.0 usb port: 1
- switch lifecycle: 10 millions
- cable length: 2m
- body dimension (lxwxh): 480x 205.5x 25mm
- fan speed: 6,000 rpm(±15%)
- max. airflow:2.7cfm
- noise level:21.7db
- rate voltage: dc 5.0v
- life expectancy: 50,000 hrs
- body dimension (lxwxh): 30x30x10mm
only £24.98 inc vat.
order now
steelseries kinzu v2 3200 dpi rubberised black gaming mouse (62022) @ £17.99 inc vat
the steelseries kinzu v2 brings together a compact and simplistic style that includes 3 programmable buttons and an optical sensor. featuring 3,200 cpi and registering 3,600 frames per second, the kinzu v2 is lightweight with a double braided nylon cord.
- number of programmable buttons: 3
- scroll wheel: yes
- number of buttons: 4
- frames per second: 3600
- inches per second: 65
- counts per inch (cpi): 400, 800, 1600, 3200
- ambidextrous: yes
- profiles available: yes
- macros available: yes
- statistics available: yes
- gold plated connector: yes
- cord material: braided
- number of illumination colors: 1
- number of illumination zones: 1
- sensor type: optical
- multiple colours: yes
only £17.99 inc vat.
order now
corsair vengeance m90 5700dpi laser gaming mouse @ £46.99 inc vat
you get maximum precision and response from the avago adns-9500 laserstream™ gaming sensor, even on high resolution displays. outpace and dominate opposing players with less accurate or slower gaming mice.
the 15 fully programmable buttons are arranged and tuned for intuitive operation without compromising your grip. you get almost effortless access to your frequently-used abilities, macros, button combinations, and spells. keep your focus on the game, and not the buttons.
the strong aluminum frame is the secret to low weight, high rigidity, and optimal mass distribution. the texturized, soft-touch surfaces are designed for comfort even after extended hours of gameplay. in short... it's designed to simply feel right.
create up to 50 profiles and share, import and export macros with the vengeance gaming mouse software. it's a free download at corsair.com.
play multiple games, with multiple character types? store up to 6 profiles in memory on the vengeance m90 laser gaming mouse, so you can easily save your character profiles, favorite macros and frequently used keys. enjoy the convenience of always having your profiles and preferences even if you switch pcs.
instantly adjust dpi for precise control when quick changes are needed between different sensitivity settings... all with the simple touch of a button.
when the action is fast and furious, you are constantly moving and repositioning your mouse. the m90 includes lift detection provides high precision tracking and reliable cursor placement even when lifted off of the mousing surface.
the solid metal, rubberized scroll wheel doesn't just feel great — it gives you the precision you need when selecting weapons. precise tactile feedback and accuracy help make sure that you select the right weapon every time.
- 5700 dpi avago adns-9500 laserstream gaming sensor
- adjustable dpi in 100 dpi increments
- 1000hz/500hz/250hz/125hz — 1msec/2msec/4msec/8msec response time — user selectable
- tracking rate of up to 165 inches per second, up to 30g acceleration, automatic frame rate control
- adjustable lift distance
- five selectable levels to fit your play style
- surface quality detection
- 15 programmable buttons
- nine ergonomically placed, side-mounted programmable buttons
- comfortable ergonomic design with soft-touch surfaces and grip improving textures
- omron left and right click switches rated for eight million operations
- 48kb of on-board memory for storing up to six "on the go" profiles with active profile led
- aluminum metal frame and base for improved rigidity and mass distribution
- solid metal, weighted scroll wheel with rubberized scroll surface for improved finger traction control and feel
- ultra low friction ptfe pads for smooth performance and accurate gliding
- usb connector with gold plated contacts
- 1.8m lightweight non-tangle cable
new firmware/software has been released for the m60, m90, and k90 products with key changes to include performance and reliability improvement.
the downloads can be found on the below links
http://www.corsair.com/us/vengeance...e-m60-performance-fps-laser-gaming-mouse.html
http://www.corsair.com/us/vengeance...0-performance-mmo-rts-laser-gaming-mouse.html
http://www.corsair.com/us/vengeance...rformance-mmo-mechanical-gaming-keyboard.html
Only £46.99 inc VAT.
ORDER NOW
Gaming is my main use but I also do a lot of typing on forums and such, I'll probably get a red switch then when I buy a mech.
Thanks ace :)
Does not having a tactile bump make it more fatiguing? Is there a lightness when you bottom out the keys or does it feel solid?
the red on the mk-85 r pretty sweet, so im guessing the reds on the -50 will be exactly the same, and i game and do a bit of typing. I only got this to replace the g-15 as it had wear n tear on the WASD keys, so, whats the first thing i did when i got this out of the box??? yup, i replaced the keys with the red uns. lol.
