**HOT GADGET SHOW & I47 GAMING DEALS - GRAPHICS CARDS!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some great deals on graphics cards to celebrate our attendance at Gadget show and I47 this weekend:-
Gigabyte ATi Radeon HD 7950 Windforce 3X 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £239.99 inc VAT
GIGABYTE introduces the latest exclusive "Triangle Cool" Technology to reach a better cooling performance. The latest patent pending technology combines fin with clip module in a special triangle shape. With the original anti-turbulence structure plus the new triangle cooling design, it enhances the efficiency of heat dissipation dramatically by minimizing the flow of turbulence between fans. Therefore, the "Triangle Cool" Technology provides a more efficient air flow for the cooling system.
Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. GIGABYTE Ultra Durable VGA can lower GPU temperature by 5% to 10%.
Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. GIGABYTE Ultra Durable VGA graphic accelerators improve overclocking capability by 10% to 30%.
Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency. GIGABYTE Ultra Durable VGA can lower power switching loss by 10% to 30%.
Features:-
- Core Clock: 900MHz
- Memory: 3072MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 1792
- Bus Type: PCI-Express 3.0
- Display Connectors: 1x Dual Link DVI, 1x HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- OpenGL 3.2 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 3 Years
- All Orders placed on the 22nd October 2012 and after shall recieve FREE copies of FARCRY3, Hitman Absolution, Sleeping Dogs PC Games along with 20% off the latest Medal of Honor WarFighter. This bundle is worth in the region of £100 and is completely FREE (Subject to availability) - You will recieve your gamecode from 2nd November onwards in the email address you provided when placing your order!
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
MSI HD 7870 Black Knight OC 2048MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
With continued demand for increased graphics horsepower to support more visually intensive games, the AMD Radeon HD 7800 Series is set to power the next generation of games and applications. And for those looking to upgrade to a next-generation graphics card, the AMD Radeon HD 7800 Series is the ideal choice.
Specification:-
- Twin FrozR Cooler with black shroud
- Core Clock: 1050MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1280
- Display Connectors: 1x Dual Link DVI, 1x Single Link DVI, 1x HDMI & 1x DisplayPort
- HDCP Capable
- DirectX 11.1 Support
- OpenGL 4.2 Support
- ATI Avivo HD
- Warranty: 3 Years
- Supplied with Nexuiz PC Game
- All Orders placed on the 30th August 2012 and after shall recieve a FREE copy of Sleeping Dogs PC Game worth £29.99 completely FREE (Subject to availability) - You will recieve your gamecode from 7th September onwards in the email address you provided when placing your order!
- All Orders placed on the 25th October 2012 and after shall recieve FREE copies of FARCRY3 PC Game along with 20% off the latest Medal of Honor WarFighter. This bundle is worth in the region of £50 and is completely FREE (Subject to availability) - You will recieve your gamecode from 2nd November onwards in the email address you provided when placing your order!
Was [£199.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Asus GeForce GTX 660 DirectCU II OC 2048MB GDDR5 PCI-Express Graphics Card with FREE Assassin's Creed III PC Game @ £185.99 inc VAT
The Geforce ™GTX 660 extends the NVIDIA Kepler™ - powered family of graphics cards to new levels of affordability while retaining class-leading performance and power efficiency. It's the weapon of choice for gamers and a must-have upgrade for today's hottest games. The Asus GeForce™ GTX 660 graphics card represents the Kepler "sweet spots" for gamers - the ultimate combination of performance, power efficiency and affordability.
Features:-
- TOP-selected 1085MHz cores run 105 MHz higher than reference for smoother gameplay.
- DirectCU achieves 20% lower temps with twice the dissipation area and 6X greater airflow than conventional design.
- DIGI+ VRM with Super Alloy Power delivers superior efficiency, reliability, and performance.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
Specification:-
- Core Clock: 1020MHz (GK104)
- Core Boost Clock: 1085MHz
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 960
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 2-Way SLI Supported)
- HDCP Capable
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 130 watts at stock speed)
- 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
- All order as of 09/11/2012 come with Assassins Creed III PC Game FREE (Download Voucher code)
Only £185.99 inc VAT.
ORDER NOW
Asus HD 7970 Matrix Platinum 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £389.99 inc VAT
The ASUS ROG MATRIX HD 7970 continues the ROG tradition of catering to overclockers who want the fastest and smoothest performance. It meets extreme tuning needs, utilizing a TOP-selected GPU factory-set to 1100MHz. For hardware-level overvolting, customers get VGA Hotwire and the TweakIt interface, with one-press 100% fan speed settings. DIGI+ VRM digital controllers and Super Alloy Power components form the basis of massive 20-phase power delivery. Exclusive GPU Tweak has been enhanced for ROG duty, adding GPU loadline calibration and VRM tuning to an already full range of parameters.
DIY modification of voltages on MATRIX HD 797 becomes simple by removing the need for complicated and risky soldering. Just connect wires from dedicated headers on compatible ROG motherboards to VGA Hotwire connectors on MATRIX HD 7970, after which you can change voltages directly on the hardware level through the ASUS UEFI BIOS or via the Windows-based Ai Suite II.
TweakIt provides flexible overclocking control even when gaming or running benchmarks! The + and - buttons put overvolting adjustments at your fingertips, with more power translating into the faster and smoother gaming you crave and the winning edge you require for intense multiplayer and competitive benchmarking.
Instantly trigger the dual 100mm fans to 100% speed regardless of driver settings. This proves very useful in extreme overclocking and other heavy workload scenarios where rapid heat evacuation and max cooling are a must.
The Safe Mode button resets the graphics card back to default frequencies and BIOS settings. This is a very useful feature for hardware enthusiasts and experimental tuning - think of it like the motherboard's clear CMOS function.
MATRIX HD 7970 is built with carefully-designed massive 20-phase power delivery, unmatched by any other graphics card for the ultimate in performance and spectacular power delivery. This ensures ample room for experimental performance tuning, as its DIGI+ VRM digital voltage regulation design augments precision overclocking capabilities, which are further supported by the use of hardened Super Alloy Power capacitors, chokes, and MOSFETs. These components are forged under extreme pressure and temperatures to increase reliability, power output, and overall card lifespan while eliminating bothersome choke buzzing noise, unlike much tamer reference cards. All these and more enable the absolute best in overclocking potential and experience.
ASUS DirectCU thermal design utilizes all-copper heatpipes so heat is removed efficiently. DirectCU II generates 6X greater airflow yet performs 3X quieter than reference in idle and full load thanks to dual 100mm sound-dampening fans.
A color-coded LED MATRIX indicator at the back of the ROG MATRIX graphics card gives real time and easy-to-understand visual display of the current GPU workload, with colors changing dynamically depending your card’s work load.
Easily fine-tune core and memory clocks, voltages, and fan settings intuitively via sliders or manual value entry. MATRIX HD 7970 arrives with a new ROG edition of GPU Tweak, which adds detailed GPU loadline calibration and VRM frequency tuning, allowing for the most extensive control and adjustment parameters for maximum overclocking potential.
Features:-
- TOP-selected 1100MHz cores run 175MHz higher than reference for smoother gameplay.
- All new MATRIX thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 12-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface
- One card drives up to six screens with AMD Eyefinity™ 6
- ROG GPU Tweak suite offers the world's first graphics overclocking tool with loadline calibration and VRM overclocking.
Specification:-
- PCI-E 3.0 Ready: Delivers double the bandwidth per lane of PCIe GEN2 for faster GPU- CPU
- Fastest single GPU graphics card on the planet
- Hugely overclockable
- Vastly cooler running than previous generation
- Quieter running than previous generation
- Compute Power: 3.5 TFLOPS
- Core Clock Speed: 1050MHz
- GPU Boost Speed: 1100MHz
- Primitive Rate: 2 prim / clk
- Shader Architecture: GCN
- Stream Processors: 32 CU / 2048 ALU
- Texture Units: 128
- ROPS / Z-Stencil: 32 / 128
- Frame Buffer / Memory: 3GB GDDR5
- Memory Width / Speed: 384 bit / 6600MHz
- Load / Idle Board Power: <300W / <3W
- Power Connectors: 8-pin + 8-pin
- 20 Phase super alloy design
- Display Outputs: 2x DVI + 4x DP
- 3yr Warranty
Was [£401.99] Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
MSI HD 7950 Twin Frozr III OC V2 3072MB GDDR5 PCI-Express Graphics Card with SIX FREE PC GAMES @ £239.99 inc VAT
nonl2br
<p><font size ="5"><b>Introduction</b></font></p>
<p>Leading global mainboard and graphics card maker MSI today announces the release of the R7950 Twin Frozr III/OC graphics card. This graphics card features the latest AMD 7950 chipset with 1792 stream processors and 3072MB of 384-bit GDDR5 high-speed graphics memory. The greatly improved overclocking potential and stability increases overclocking performance up to 37.5%! The highly acclaimed Twin Frozr III thermal design with 8cm Propeller Blades fan setup for 20% more air flow and 8mm SuperPipe technology is used for cooling. Fan noise of just 30dB at full load provides gamers the most silence user experience, while MSI Military Class II components are used to give the highest quality and stability. For gamers seeking overclocking potential, cooling and stability, the R7950 Twin Frozr III/OC graphics card offers the perfect solution!</p>
<p>
<font size="5"><b>Key Features</b></font></p>
<table style="border-width: 0 0 0px 0px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" width="95%" border="0" cellspacing="0" align="center">
<tr valign="middle">
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="150"><img src="http://marketing-uk.msi.com/images/MCII.jpg" width="150"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="*">
<font color="blue" size="4"><b>Military Class II</b><br>
<font color="black" size="3"><b>Top Quality and Stability - </b>Components tested to US Military Standards Delivering Higher OC Capability, Better Power Efficiency, Longer Lifespan!</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 0px 0 0px; border-style: solid; border-color: #dcdcdc;" width="5px">&nbsp;</td>
<td style="vertical-align: middle; padding: 4px; border-width: 0px 0px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://marketing-uk.msi.com/images/Propellorblade.png" width="150"></td>
<font color="blue" size="4"><b>Propellor Blade Fan Technology</b><br>
<font color="black" size="3">MSI's exclusive fan blade design generates 20% more airflow covering wider area for the better heat dissipation.Only 30dB & 66Cunder full load!!!
</font></font></td>
</tr>
</table>
<p><font color="black" size="5"><b>Full Specifications</b></font><br>
<p><font color="blue"><b>Cooling: </b></font>MSI Twin Frozr III Dual Fan Heatpipe Cooler For Maximum Cooling Potential and Low Noise</p>
<p><font color="blue"><b>Memory: </b></font>3072MB GDDR5</p>
<p><font color="blue"><b>Memory Clock: </b></font>5000MHz (effective)</p>
<p><font color="blue"><b>Memory Interface: </b></font>384-Bit</p>
<p><font color="blue"><b>Shaders: </b></font>1792</p>
<p><font color="blue"><b>Bus Type: </b></font>PCI-Express 3.0</p>
<p><font color="blue"><b>Display Connectors: </b></font>2x Mini DisplayPort, HDMI, DVI-I</p>
<p><font color="blue"><b>Crossfire: </b></font>Up to 4 Way Support</p>
<p><font color="blue"><b>HDCP: </b></font>Yes</p>
<p><font color="blue"><b>DirectX 11: </b></font>Yes</p>
<p><font color="blue"><b>Open GL 4.2: </b></font>Yes</p>
<p><font color="blue"><b>Eyefinity: </b></font>Yes</p>
<p><font color="blue"><b>Powerplay: </b></font>Yes</p>
<p><font color="blue"><b>AVIVO HD: </b></font>Yes</p>
<p><font color="blue"><b>Warranty: </b></font>3 Years</p><br>
- All Orders placed on the 9th November 2012 and after shall recieve FREE copies of FARCRY3, Hitman Absolution, Sleeping Dogs, Dirt Showdown, Nexuiz, CODMW2 PC Games along with 20% off the latest Medal of Honor WarFighter. This bundle is worth in the region of £100 and is completely FREE (Subject to availability) - You will recieve your gamecode from 2nd November onwards in the email address you provided when placing your order!
Was [£263.99] Inc. VAT
ORDER NOW
Asus GeForce GTX 690 4096MB PCI-Express Graphics Card @ £779.99 inc VAT
The new ASUS Geforce® GTX690-4GD5 graphics card ships with Dual 28nm NVIDIA® GPU and 4GB GDDR5. To fully harness the power of dual-GPU technology, GTX690-4GD5 comes with ASUS exclusive GPU Tweak utility and NVIDIA® GPU Boost clock speed modulation that provides the fastest gaming performance. ASUS Geforce® GTX690-4GD5 offers gamers improved tuning access, and ultra-smooth gaming experience through NVIDIA® Adaptive VSync technology. It also supports NVIDIA® 3D Vision® surround™ on hundreds of PC games with a single card. Moreover, the card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0.
Features:-
- Dual 28nm GPU with 4GB GDDR5
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- Bring games to life with NVIDIA® Surround™ multi-monitor gaming on a single card
- PCI Express 3.0 Delivers double the bandwidth per lane of PCIe Gen 2 for faster GPU - CPU communication
Specification:-
- PLX PCI-E 3.0 Bridge Chip (Gen3)
- Core Clock: 915MHz (GK104) x2
- Core Boost Clock: 1019MHz x2
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Memory: 4096MB GDDR5 (2x 2GB)
- Memory Interface: 512-Bit (2x 256-Bit)
- Processing Cores: 3072 (2x 1536)
- Display Connectors: 3x Dual-Link DVI-I, & 1x Mini-Displayport
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 300 watts at stock speed)
- 2x 8-Pin PCI-E Connectors required
- Dimension: The card size is 11x4.4x1.9inches
- Warranty: 3yr
Was [£799.99] Inc. VAT
Only £779.99 inc VAT.
ORDER NOW
Gigabyte HD 7770 OC 1024MB GDDR5 PCI-Express Graphics Card w/ FARCRY3 & 20% MOH WarFighter PC Games @ £89.99 inc VAT
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using Ferrite Core Chokes, Low RDS (on) MOSFET and Lower ESR Solid Capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics cards now feature a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
Gold plated, durable large contact area connectors have been used for optimum signal transfer between connections.
As opposed to the stereotype, GIGABYTE is able to maximize fan size to 10cm with the latest cooling design. With a 10cm fan, the card is virtually silent that its noise level runs much lower
Features:-
- Memory: 1024MB GDDR5
- Memory Interface: 128-Bit
- Processing Cores: 640
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was [£101.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Asus GeForce GTX 680 DirectCU II 2048MB GDDR5 PCI-Express Graphics Card with FREE Borderlands 2 & Assassin's Creed III PC Games @ £399.95 inc VAT
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- All new DirectCU thermal design utilizes five all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 10-phase Super Alloy Power technology delivers precise digital power and enhanced overclocking headroom.
- GPU Tweak utility helps you modify and tune boost clock, power target , and fan performance via an intuitive interface
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1084MHz
- Processing Cores: 1536
- Shader Clock: 2012MHz
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 3 Years
- All order as of 09/11/2012 come with Borderlands 2 & Assassins Creed III PC Games FREE (Download Voucher codes)
Was [£429.95] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
MSI HD 7850 OC 1024MB GDDR5 PCI-Express Graphics Cards w/ FARCRY3, Nexuiz & Sleeping Dogs PC Games @ £125.99 inc VAT
Features:-
- Processing Cores: 1024
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- Shader Model 5.0 Support
- ATI Avivo HD
- Warranty: 2 Years
Was [£139.99] Inc. VAT
Only £125.99 inc VAT.
ORDER NOW
MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards w/ FARCRY3 & Sleeping Dogs PC Games @ £149.99 inc VAT
nonl2br<Font size="4"><b>Key Features</b></font><br>
<br>
<b>Propeller Blade on Twin Frozr III</b><br>
- The special blade design generates 20% more airflow than traditional design.<br>
- 10C cooler & 13.7dB quieter than reference design!!!<br>
<br>
<b>MSI Afterburner overclocking utility</b><br>
- Supports overvoltage function<br>
- Supports advanced fan speed control.<br>
- Supports burn-in stability test. <br>
<br>
<b>All Solid Capacitors</b><br>
- 10 years ultra-long lifespan<br>
- Lower Temperature and Higher Efficiency<br>
<br>
<b>AMD Eyefinity Technology Support</b><br>
- AMD Eyefinity Technology supports maximum 6 displays with 2 DisplayPorts via Multi-Stream Transport (MST HUB).<br>
<br>
<Font size="4"><b>Specifications</b></font><br>
<b>Graphics Engine</b> ATI Radeon HD 7850 <br>
<b>Interface</b> PCI Express x16 3.0 <br>
<b>Memory Type</b> GDDR5 <br>
<b>Memory Size(MB)</b> 2048 <br>
<b>Memory Interface</b> 256 bits <br>
<b>Core Clock Speed(MHz)</b> 900 <br>
<b>Memory Clock Speed(MHz)</b> 4800 <br>
<b>DVI Output</b> 1 <br>
<b>HDMI-Output</b> 1 <br>
<b>Mini DisplayPort</b> 2 <br>
<b>HDCP Support</b> Y <br>
<b>HDMI Support</b> Y <br>
<b>Dual-link DVI</b> Y <br>
<b>Display Output (Max Resolution)</b> 2560x1600 <br>
<b>RAMDACs</b> 400 <br>
<b>DirectX Version Support</b> 11 <br>
<b>OpenGL Version Support</b> 4.2 <br>
<b>CrossFire Support</b> Y <br>
<b>Card Dimension(mm)</b> 197 x 111 x 38mm <br>
<b>Warranty</b> 3 Years<br>
- All Orders placed on the 30th August 2012 and after shall recieve a FREE copy of Sleeping Dogs PC Game worth £29.99 completely FREE (Subject to availability) - You will recieve your gamecode from 7th September onwards in the email address you provided when placing your order!<br>
Was [£169.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Asus HD 7970 DirectCU II 3072MB GDDR5 PCI-Express Graphics Card with FREE FARCRY3, Hitman Absolution, Sleeping Dogs & 20% off MOH Warfighter PC Games @ £319.99 inc VAT
The next generation Asus HD7970-3GD5 graphics card has arrived, fitted with a 28nm GPU that packs 4.3bn transistors and is combined with 3GB GDDR5 Memory, it provides users with the speed for smoother gaming. Supporting full DirectX 11, AMD CrossFireX and AMD HD3D, the GPU includes an exclusive tweak utility which allows users to tune the performance of up to four graphics cards and check card status via an intuitive interface.
This GPU Tweak function links the GPU clock frequency to the voltage, so as you scale the GPU clock the voltage automatically follows; a useful tool for inexperienced Overclockers, It also enables users to select between 2D and 3D mode by providing the ability to change the respective clock speeds, voltages and fan speeds of either. Disabling the 2D mode also forces the faster 3D mode, stabilising overclocking and benchmarking results.
Embedded with GPU-Z to access accurate graphics card information, the card also contains a live update driver and BIOS benefiting users with the ability to keep their card in the best condition. Widget monitoring provides the choice to display the most needed information including a full widget, light widget or real time monitoring.
Furthermore, new PCI Express 3.0 delivers improved encoding and twice the performance of the previous PCI Express 2.0 and vision horizons can be expanded across six displays with AMD Eyefinity technology. This technology delivers innovative graphics display capabilities enabling massive desktop workspaces and ultra-immersive visual environments for the ultimate panoramic computing experience.
Features:-
- All new DirectCU thermal design utilizes six all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Core Clock Speed: 925MHz
- Memory Width / Speed: 384 bit / 5500MHz
- Display Outputs: 1xDVI + 2x mDP + 1x HDMI
- 3yr Warranty
Was [£359.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 670 FTW 2048MB GDDR5 PCI-Express Graphics Card with FREE Borderlands 2 & Assassin's Creed III PC Games (02G-P4-2678-KR) @ £299.99 inc VAT
Get to the next level with the EVGA GeForce� GTX 670. This card delivers truly game-changing performance that taps into the powerful new GeForce� architecture to redefine smooth, seamless, lifelike gaming. It offers brand new, never before seen features that will redefine the way you think about performance graphics cards. Expect more from your graphics card than just state-of-the-art features and technology; get a faster, smoother and richer gaming experience with the EVGA GeForce� GTX 670.
Faster:
- Innovative new GeForce architecture-designed to deliver faster, more power-efficient performance
- The power to turn on lightning-fast antialiasing in a huge variety of games, automatically, with NVIDIA FXAA
- Support for new temporal antialiasing (TXAA) technique that delivers the ultimate combination of image quality and performance.
Smoother:
Richer:
- NVIDIA® Surround™ multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display)
Specification:-
- Uses GTX 680 PCB and GTX 680 Cooler for superior OC potential & performance!!
- Core Clock: 1006MHz (GK104)
- Memory Clock: 6208MHz (Effective)
- Processing Cores: 1344
- Shader Clock: 1830MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- Warranty: 3 Years
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Asus GeForce GTX 670 DirectCU II 4096MB GDDR5 PCI-Express Graphics Card with FREE Borderlands 2 & Assassin's Creed III PC Games @ £383.99 inc VAT
The new Asus GTX670-DC-2GD5 with Digi+ VRM for the ultimate power control and enhanced Overclocking comes with the Asus exclusive DirectCU II for up to 20% better cooling.
The GeForce GTX 670 graphics card taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It's more than state-of-the-art technology and features. It's truly game-changing performance.
Faster:
Smoother:
Richer:
Features:-
- Double the reference video memory at 4GB takes your gaming to new levels of smooth.
- Flattened copper heatpipes makes direct contact with the GPU surface so heat is dissipated efficiently, delivering a 20% cooler and vastly quieter performance than reference.
- Acclaimed DIGI+ VRM with 8-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking.
- GPU Tweak utility helps you modify and tune clocks (including new boost clock settings), power consumption targets, voltages, and fan performance via an intuitive interface
Specification:-
- 20% cooler and Vastly quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS DIGI+ VRM technology with 6+2 phase Super Alloy Power for precise digital delivery and enhanced overclocked headroom. (compared to 4+2 phase in reference card)
- GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
- Full length PCB, better for overclocking
- Core Boost Clock: 980MHz
- Shader Clock: 1960MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£399.95] Inc. VAT
Only £383.99 inc VAT.
ORDER NOW
Some great deals to take advantage of this weekend guys! :)
anyone know what the windforce 7950 clocks like?....i know the 670 one clocks great cos have one but unsure about this 7950, and need a new card for the all knowing one as hers has turned its toe's up.
Guys
Is it worth upgrading from an MSI 6950 to a 7950, I normally play ARMA II and Planetside @ 1080..
Running with a I5 2500k at 4.2.
Thanks
in general 7950's clock very very well but its a bit of a lottery if any card clocks well. nvidia or amd its chance if you get a good clocker.
the 7970 matrix is almost certain to be a good clocker as asus will of picked the best chips for that card
id go for this though
http://www.overclockers.co.uk/showproduct.php?prodid=GX-097-GI
£299 for a 7970 windforce is incredible. get it quick!
yeah jamsames i agree about the matrix but that's just to costly atm...and the 7970 windforce is certainly on my radar..tis all about the penny's :)
