This is really what it comes down to..
AMD Bringing out drivers that work really well with there new products, But bring a world of issues for the slightly older cards.
I've had a 6950, worked fine on the latest drivers with no issues at all. I've now got 2x 7950s on the latest drivers, they're fine too.
Just because you're having issues, doesn't necessarily mean it's the graphics drivers that's definitely to blame. Have you tried the cards independently, for example?
People have similar issues with nVidia cards at times too, it's just that sort of thing that happens at times.
			I have seen something similar
I have a pair of old HD 5970s which I run in quadfire
If I use drivers 10.4 something like 3dmark11 runs fine, if I use the up to date drivers it does not.
I think I remember reading your issues on this, isn't it solely 3D Mark 2011? I'm pretty sure you said that games were fine, but it was just 3D mark that wasn't running on all 4 GPUs?
It's fair enough to be annoyed at the fact that it's not working of course, but they're old GPUs, that I recall worked fine in everything except 3D Mark 2011, which is arguably quite unimportant since it has no real world relevance to the intended usage of the graphics cards (games).
			@Rusty you place too high a value on overclocking.
I have noticed many times that and overclocked setup will bench far faster than a stock setup, however you seem to get more little stutters etc with an overclocked rig.
A 'stock' system can feel far smoother than an overclocked one, especially the sort of overclocks you are referring to.
You shouldn't be giving anyone advice because you very clearly have absolutely no idea what you are talking about. Your post suggests that the lower the clockspeed, the smoother the performance which is just utter rubbish.
The stock/reference clockspeeds of cards is a fairly arbitrary number in relation to the core itself. In the case of 7950s, they are effectively "underclocked" quite a bit (at least 25%) compared to what the core itself is capable of. To suggest that increasing the core frequency means that the games stutter more implies that the stock/reference clockspeed has some significance to the core itself.
I think the real issue here is that you're really bad at overclocking so you've convinced yourself that overclocking is crap and you didn't want to do it anyway, to cope with the fact that you're not very good at it.
