does it play 3d iso etc ?
Not sure to be honest mate. Haven't got any 3d iso's.
have you got a setup guide or links at all ?
You cam PM me if you like
Not a lot of info on this & pulse-eight site is crap ...
What skin is that? I run XBMC on my pc just as an standalone prog rather than an OS - i use either keyboard or HTC One X as remote.
this looks pretty great...so does one of the models come preinstalled with xbmc?
also, what ram does this take? I think i'd like to get 4 gigs instead of 2..
Looks good. What chipset does it use? Would also like to know if it can play back a Bluray ISO as that is something my Dune HD Smart cannot do. This might be a good alternative the Popcorn Hour.
which software did u d/l of pulse-eight site ?
Quite a few diff versions in packages
I used the openelec pulse version. Installed in under 10 mins and everything just worked.
There is four versions
fusion
Generic
Intel
nVidia
lol sorry for all the questions but cant wait to get it![]()
The premium takes sodim. Standard takes standard ddr3. I've stuck a single 4gb stick in but another 4gb is on its way just because it was so cheap.
Is the premium version not available any more? Can't find it on their website.
