I've been scouting around, I haven't seen any voltage locked Gigabyte 7950 posts as yet, I think Gigabyte only did it with the 7970's, so that the Ghz Edition would look a more appealing purchase.humbug said:The 7950 is better bang for £ at £50 less.
About 10% higher OC than the 7970 will match it.
If i was going to recommend a 7950 the Gigabyte would be it, i have the 7870 version of it, mine is not a good clocker at all, THE worst i have seem from Gigabyte (sods law) but i'm still able to run it 1200 / 1500 24/7 @ 1.26v, i have seen a lot of others do that at stock (1.22v) and 1300Mhz at my volts. the 79## series GPU's will not do that anywhere near as easily, but still very good.
+ Gigabyte have a good UK based RMA.kissenger said:It depends on if the WF7950 is voltage locked too. I don't know if it is. FWIW, I had one of those 1000 core WF 7970s and I clocked it to 1050/1600 stable, but it wouldn't go any higher and I had no option to adjust voltage. I went with a reference MSI 7970 for 300GBP and I'm happy with it. I don't know why, but they seem to clock really well. Everyone I know with one got good clocks out of theirs. I have mine 100% stable at 1175/1725 and can do 1200/1800 in benches.
Only downside is a lot of noise with big overclocks due to the reference fan, but it's not that big of a deal if you game with a headset on.
Cheers...TaKeN said:They clock down Nelly![]()
Ahh that was you? I read your post on the Gigabyte forum, seems they fixed the normal 7970, but not the GHz version. Maybe they fix it soon. Yeah I think I'll get the 7950.ICDP said:The Windforce 3X GE is not a good card for the price.
- 50% fan speed in idle 2D clocks. So it is loud unless you use MSI Afterburner. I raised a support ticket with Gigabyte re a new BIOS to fix this, 8 days later they still haven't responded.
- Locked voltage. You are stuck with 1.256v, no way to adjust.
Save the money and get a non GE 7970 or 7950.
Cheers...Ahh that was you? I read your post on the Gigabyte forum, seems they fixed the normal 7970, but not the GHz version. Maybe they fix it soon. Yeah I think I'll get the 7950.
