And still require 5 arrows to a Tiger's face to kill it? Stick with my flamethrower thanks.
Only upside to the bow is the unlimited ammo and semi-awesome feeling of long range shots, it's **** for hunting, absolutely ****, and that's exactly why I would use a bow in the first place. :/
How do u get unlimited ammo. I bought the bow and had 5 arrows i used them all and it was done, waste of money better with a gun at least u can pick up enemy ammo if u run out
Just walk over the enemy you killed and you'll pick up the arrows automatically. It's not unlimited as much as reusable once it's safe to go in and recover them.
2hrs in and im not geting into it does it get better?
Problem with thse open world type games is the stop start nature and periods of nothingness.
Take FC1 for example or black mesa a recent game im playing its action always.
Um, whereabouts is that Dr Reinhardt guy you're supposed to go see after you've cleared out the very first camp (don't think that's worth spoilering to be honest). I wandered off and did a couple of sidequests and I now have no idea where this Dr guy is, he's not marked on the map.
Besides that.. some early frustrations:
- The keys to switch off radio, change song, etc don't work if they've been remapped.
- Can't bind numpad enter (nor enter for that matter - but there is a workaround for that)
- Some pretty noticeable choppiness in places, during fights it seems, and that's with 2 x GTX 690s (running everything on max in 2560x1600, except MSAA at 2x)
I also did have for a brief moment the FarCry 2 experience all over again... had a great moment where I inadvertently drove through a bandit roadblock, they gave chase and I stacked the car and fell into the sea. When I got back out I ended up having to spend the next 10 minutes dealing with car after car after car of bandits turning up. By the end there were like 7 jeeps in the same place.
Snip
Is your card OC'd? If so, put it back at stock.
Oh dear, new patch this morning and now no crosshair on my sniper scope :/
I'm experiencing texture shimmering, regardless of the levels of MSAA.
