Windows 8 licensing
Caporegime
19 Apr 2008
Essex
I installed Windows 7 Home Premium on my new build using a disk I had already, however I do not want to activate it yet as my other PC is using this licence. If I buy a full copy of Windows 8, can I run upgrade my existing installation to Windows 8 and validate it using the code from the copy I've purchased? I'm sure it will work but I wanted to run it by the forum first in case I'm missing something.
Well, technically your shouldn't as it's in breach of whatever agreements you accept on install. I would say try it and see, I'd imagine it'll probably work.
Note: If it won't activate over the internet ring the number instead and, when asked by the nice microsoft lady, select 1 for number of installs.
So you want windows 8 on your new build but you want to get away with only paying the upgrade price whilst keeping the windows 7 license you have on another machine?
I would be surprised if it worked and really you shouldnt be doing it.
Good luck though.
if u buy a windows 8 oem then yes u can keep windows 7 also,
but if u buy a windows 8 upgrade then no u can't keep windows 7
windows 8 oem = is a full standalone license
windows 8 upgrade = is it takes over your previous license.
I think Windows 7 needs to be activated before you can run the upgrade assistant? Either way, I bought and upgraded my illegitimate Win7 to Win8 and it worked fine :p
Not in my experience, purchased Windows 8 using an clean unactivated Windows 7 install. They might of changed it though.
Good luck though.
I don't think you really read the OP - I installed with a Retail copy of 7 which I haven't activated and I wanted to just upgrade to Windows 8 using a full Retail licence. Anyway I just bought an OEM copy of 7 and activated it that way, decided against upgrading for the time being.
