I know, string me up! I don't have the budget or testicular diameter to do a custom loop, and I was thinking of making some space in my case by getting rid of my gigantic heatsink. My Thermaltake Frio is great and quiet too, but it's too tall for me to mount a side-fan. Since my GPU is the noisiest part of my rig, I'm hoping a side fan will help me push my GPU fan speeds down a bit. So as long as performance/noise is as good as the Frio I'll be happy.
My case is an NZXT Phantom Enthusiast (the original full tower version), and I've heard mutterings about some rads not fitting with the top fans installed. That wouldn't be a huge issue because I could take the roof exhaust and mount it on the side panel, and then use some 120mm fans in push-pull (I'm not 100% sure I can fit that up there, if anyone else knows?).
I looked at the H100, but the word on the street is that the pump isn't great quality and some have failed, not to mention poor flow rates and noisy stock fans. So I'm not really sure which to go with.
What do you liquid gurus suggest?
E: in terms of budget, if it's a good investment, I don't mind spending extra, but I don't think I'd want to spend over £100 unless there was a very good reason.
I think my current air solution would put me at high risk of degradation with 5ghz temps.
) and when fitted (it just in fact slots in and has held, without issue, for nearly a year) clearance was fine. - I moved the nzxt 200mm that the case came with to the top slot towards the front of the case where it exhausts the air nicely.
