Who likes pretty LED's?
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Enermax Vegas Trio Fans to be exact.
Here is a little home made video I just created. So you can all see the LED quality and options.
Enermax T.B.VEGAS TRIO vUCTVT12P 120mm Fan @ £19.99 inc VAT
Bright Colours
Eye-catching and bright colours thanks to patented circular LED light with 54 diodes (18 blue, 18 red and 18 green diodes). Enermax LED fans shine many times brighter than ordinary LED fans.
Spectacular Three-colour (blue/red/green) Light Show
The leading Enermax LED technology creates unmatched effects due to the patented circular LED light with 54 diodes (18x blue, 18x red, 18x green). Three colours (Blau, Rot und Grün) and 14 LED modes to choose from. LED mode button included.
Curved LED flashes
Focus Blades with light reflex strips to create exceptional, curved rays of light.
Powerful Cooling
High-performance Turbine Blades providing an air flow rate of max. 114m3/h.
Flexible Speed Control
RPM adjustment with 4-pin PWM mainboard fan control.
Twister Bearing
Smooth and persistent silent thanks to patented Twister Bearing Technology (min. 100,000 hours MTBF).
Click Mechanism
Detachable blades for easy cleaning from dust.
Effective vibration reduction
Four isolator mounts reduce vibrations and make the fan installation easier.
Only £19.99 inc VAT.
ORDER NOW
CLICK HERE FOR FULL ENERMAX FAN RANGE
they look awesome, cost a pretty penny though.
have you mounted one to case and tested noise? for 20 quid a pop i'm assuming there pretty dam quiet?
I have that one still running under my desk. It is near silent. My XFX 5970 is not however.
Love the idea of detachable blades for cleaning. Not too fussed on the lighting though. Do they do a cheaper version without all the fancy christmas lights?
Hi there
I was pretty amazed by these earlier, awesome fans and some of the brightest I've seen. :)
Shut up and take my money...
DEAL! I will be honest I'm not even the fan buyer/product manager at OcUK (I used to be, but we swapped a few of the categories round) but these fans were that cool (no pun intended) that I just had to create the video and upload it. Thats how impressed I was.....
lets hope whoever wins them in the enermax comp will make a nice vid in their finished rig :)
It'd be better if there was a transition between colours rather than an instant change, IMO.
