Running 2x IceQ 7950s Crossfire these bugs happen if crossfire is enabled or disabled.
I want to know if there bugs or driver issues as i have just bought these cards and bit paranoid...
First issue is METRO 2033, artifacting on the main menu when DX9 mode and AAA is enabled, Snoke poping effect on the EXIT DOOR and sharp tairing at the sides of the screen.. also when you have a pistol equipped and you look at your watch top right corner of the wrist band for pixel colors flickering and big pixel poping.... only happens when viewing the watch and when viewing it under a light source like a light.
Next FARCRY 3. this is the most annoying one
when the game autosaves it will save then screen will pop a checkerboard effect on the screen then vanish instantly. does it at various autosaves through out the game.
also the same effect will happen when your running into a area that is preloading as your aproche and if you look at certain area it will flicker the chequerboard effect and vanisha again........
like i said these issues are making me paranoid and within good reason to, i have reproduces these issues with crossfire enabled or disabled or taking both cards out of my system and putting one in at a time no matter what without fail these issues appear...
whats the chances of my luck in getting 2 broken cards ? with the exact same issues.
