Buying a router abroad
8 Jan 2003
Scotland
A Linksys router I have been looking at is available for £60 cheaper from a reputable Spanish online website than it would be to buy direct in the UK. Other than the plug, is there likely to be any issues with buying a router from Spain and using it in the UK?
Check the voltage input of the router is the samd
Check the admin language can be changed
Check the duty payable on it with hmrc
There are some legalities around wifi channels/frequency but I think only between the UK and USA.
