Will I be able to power 4 fans?
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
3 x Optional Fan connector(s)
That is what the Motherboard states. So yes, easily.
You don't need to plug fans into the motherboard for power though as they can run of PSU peripheral cables (using 4 pin to 3 pin connectors if needed)
When connected to the power supply, the fans will run at 100% speed. Whereas if connected to the motherboard, they can be speed controlled. Another option is a fan controller, should you wish to add one later.
Very true,
Using one of these (when plugged into the PSU) reduces speed by around 15% i think.
YOUR BASKET
1 x Akasa 3-Pin Fan Speed Reduction Cable (ACA99*2/12) £1.99
Total : £4.27 (includes shipping : £1.90).
Motherboard would be the best place to put them though.
Cheaper to just plug em into the motherboard, I have 3-pin fans and use the "Voltage" PWM control option in my Gigabyte BIOS, Asus should have similar. I think Asus can control from the Thermal suite in windows.
