Can't wait to see this finished as interested in the benefit of WC'ing the mobo.
I take it your putting your 690's in it?
Or are you getting something different?
YOUR BASKET
1 x XSPC RX240 120mm Radiator - Black £65.98
4 x EK-PSC Adapter Rotary 90° G1/4 Black Nickel £3.59 (£14.36)
4 x EK-PSC Adapter Rotary 45° G1/4 Black Nickel £3.59 (£14.36)
2 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£5.98)
Total : £100.66 (includes shipping : FREE).
I am not so great at this but this is what I would add. I wouldn't fuss over a 120 Rad and go straight for a 240. I am sure I have read on another thread that you can easily get a 360+240 in the 800D but would like confirmation before you order.
I added crap loads of 45 and 90 degree fittings and they make it so much easier to fit the pipes cleanly. You decide on the amount you want bud. Also, I added 2 more compression fittings, as you will need them for the extra rad. Not sure on all the other bits like mobo connectors you need, so add 2 for each water cooled part.
I love those fans and regret not getting them. Only reason I have not changed them is because you can't see my fans at all
On a side note, that pastel light red has gone a little pinkish...Myabe the dark red coming soon would be better![]()
You can go 360 + 120 in an 800D without modding, with modding the options are endless tbh, I'm going for 480 + 360 in my 800D with a new motherboard tray.
And yes, buy LOTS of angle fittings, it makes life so much easier
Be careful adding compressions to motherboard blocks, the ports are very closely packed.
Any reason for staying with the 800D? The switch 810 allows for fat 240+360 rads easily and as NickolP did, you can even put a 240 on the front (I wish I had now).
I had never seriously considered water cooling because of putting water with expensive components is not a good idea but after convincing myself "Man up and get it done" I am so glad I did. Space/time/planning are the important factors IMO.
The toolkit is a bit meh tbh but does a fairly decent job bro. I got fed up of having to go down the shed to get my tools and wanted something that had it all in one bag and this does. It has the anti static wrist strap thingy but I didn't bother with that but it is a good thing to use (apparently).
I would like to add another 360 to mine or add a rad outside with very very long pipes. I am not sure I can do that though and don't much see the need. I would use the koolance quick disconects for the outside rad if I did do it.
I was thinking of doing a similar kind of mod Pgi did with his 800D. Strap a huge rad to the side of the case, it would be the cheapest alternative for extra rad space for me...other than getting the TH10 i keep looking at.
I've got one of those toolkits, bought for the same reason. It's not too bad tbh, does the job...not used the anti static thing though, doubt i ever will.
As for draining, my 240 rad has a plug on the bottom, just above the dust filter on the 810.
This is how mine is but have not had to drain yet, tonester, does it splatter when you remove plug?? Big bucket??
That is not good Kaap. When you say "one of the pumps is missing", I take it you mean completely not there? I would report this in the customer services section bud. I would not be happy either and gutted for ya.
which kit?
Hi sorry to hijack this thread but I've noticed there's a lot of these threads so didn't want to create another one unless the op wishes me to.
I've been reading up on watercooling for a few months now and I think I'm finally ready to take the plunge, these are my specs.
Corsair 600T se white
Asus P8Z77-V PRO
i5 3570k @ 4.4GHZ
Corsair Memory Vengeance Low Profile Blue 2x4GB
Asus d2x
Asus directcu ii 670 2GB
Be quite dark pro 10 850W
Now I know the 600T isn't ideal for watercooling but I love this case and have added a sound dampening kit to it. I'm not afraid to use a dremel either and have seen on another site (think it was overclock3d) that you can fit a rad with a tiny bit of modding, I think it was the XSPC EX360. I'm hoping it would fit and wondered if anyone here has done it, I know I'd then have to put the fans in the grill like with the H100i. I want to but the Overclockers V12 set and add this water block.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-297-EK&groupid=962&catid=1520&subcat=2328
Would one 360 rad be enough to cool the 3570k and the 670 with low noise? as I don't really want to add a 200mm rad at the front.
Any help or advice would be really appreciated.![]()
