Far Cry 3 Thread
I liked them :p
The problem with the respawning enemies both in FC2 and 3 is that it pulls you out of the experience and shoves you, head first, into a pure game.
For those who like repetitive games the FC series has become great fun. For those who like simulating reality and getting immersed in any way, they have turned into a bit of a disappointment. Not an entirely lost cause, but a very Just Cause.
I don't like repetitive games. But I could always just avoid spawns if I didn't want a fight... I never saw the problem.
multiplayer is terrible
u cant choose server and it connects you to people with bad pings and get so many games that end prematurely esp in coop
rant done and along with this game
Got some settings?
/ Choose effects /
// Set to 1 for ON or 0 for OFF
#define USE_SMAA_ANTIALIASING 0 //[0 or 1] SMAA Anti-aliasing : Smoothens jagged lines.
#define USE_LUMASHARPEN 0 //[0 or 1] LumaSharpen : Also sharpens the antialiased edges which makes them less smooth - I'm working on fixing that.
#define USE_BLOOM 0 //[0 or 1] Bloom : Makes bright lights bleed their light into their surroundings (relatively high performance cost)
#define USE_HDR 0 //[0 or 1] HDR : Not actual HDR - It just tries to mimic an HDR look (relatively high performance cost)
#define USE_TECHNICOLOR 0 //[0 or 1] TECHNICOLOR : Attempts to mimic the look of an old movie using the Technicolor three-strip color process (Techicolor Process 4)
#define USE_DPX 1 //[0 or 1] Cineon DPX : Should make the image look like it's been converted to DXP Cineon - basically it's another movie-like look similar to technicolor.
#define USE_LIFTGAMMAGAIN 0 //[0 or 1] Lift Gamma Gain : Adjust brightness and color of shadows, midtones and highlights (avoids clipping)
#define USE_TONEMAP 1 //[0 or 1] Tonemap : Adjust gamma, exposure, saturation, bleach and defog. (may cause clipping)
#define USE_VIBRANCE 0 //[0 or 1] Vibrance : Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
#define USE_CURVES 0 //[0 or 1] Curves : Contrast adjustments using S-curves.
#define USE_SEPIA 0 //[0 or 1] Sepia : Sepia tones the image.
#define USE_VIGNETTE 0 //[0 or 1] Vignette : Darkens the edges of the image to make it look more like it was shot with a camera lens. May cause banding artifacts.
#define USE_DITHER 0 //[0 or 1] Dither : Applies dithering to simulate more colors than your monitor can display. This lessens banding artifacts (mostly caused by Vignette)
#define USE_SPLITSCREEN 0 //[0 or 1] Splitscreen : Enables the before-and-after splitscreen comparison mode.
/ SMAA Anti-aliasing settings /
#define SMAA_THRESHOLD 0.12 // [0.05 to 0.20] Edge detection threshold
#define SMAA_MAX_SEARCH_STEPS 16 // [0 to 98] Determines the radius SMAA will search for aliased edges
#define SMAA_MAX_SEARCH_STEPS_DIAG 6 // [0 to 16] Determines the radius SMAA will search for diagonal aliased edges
#define SMAA_CORNER_ROUNDING 0 // [0 to 100] Determines the percent of antialiasing to apply to corners.
// -- Advanced SMAA settings --
#define COLOR_EDGE_DETECTION 1 // [0 or 1] 1 Enables color edge detection (slower but slightly more acurate) - 0 uses luma edge detection (faster)
#define SMAA_DIRECTX9_LINEAR_BLEND 0 // [0 or 1] Using DX9 HARDWARE? (software version doesn't matter) if so this needs to be 1 - If not, leave it at 0.
/ LumaSharpen settings /
// -- Sharpening --
#define sharp_strength 0.60 // [0.10 to 3.00] Strength of the sharpening
#define sharp_clamp 0.035 // [0.000 to 1.000] Limits maximum amount of sharpening a pixel recieves - Default is 0.035
// -- Advanced sharpening settings --
#define pattern 2 // [1|2|3|4] Choose a sample pattern. 1 = Fast, 2 = Normal, 3 = Wider, 4 = Pyramid shaped.
#define offset_bias 1.0 // [0.0 to 6.0] Offset bias adjusts the radius of the sampling pattern.
// I designed the pattern for offset_bias 1.0, but feel free to experiment.
// -- Debug sharpening settings --
#define show_sharpen 0 // [0 or 1] Visualize the strength of the sharpen (multiplied by 4 to see it better)
/ Bloom settings /
#define BloomThreshold 20.25 //[0.00 to 50.00] Threshold for what is a bright light (that causes bloom) and what isn't.
#define BloomPower 1.446 //[0.0000 to 8.0000] Strength of the bloom
#define BloomWidth 0.0142 //[0.0000 to 1.0000] Width of the bloom
/ HDR settings /
#define HDRPower 1.20 //[0.0 to 8.0] Strangely lowering this makes the image brighter
#define radius2 0.80 //[0.0 to 8.0] Raising this seems to make the effect stronger and also brighter
/ TECHNICOLOR settings /
#define TechniAmount 0.11 //[0.0 to 1.0]
#define TechniPower 2.8 //[0.0 to 8.0]
#define redNegativeAmount 0.88 //[0.0 to 1.0]
#define greenNegativeAmount 0.88 //[0.0 to 1.0]
#define blueNegativeAmount 0.88 //[0.0 to 1.0]
/ Cineon DPX settings /
#define Red 15.0 //[1.0 to 15.0]
#define Green 15.0 //[1.0 to 15.0]
#define Blue 15.0 //[1.0 to 15.0]
#define ColorGamma 1.0 //[0.1 to 2.5] Adjusts the colorfulness of the effect in a manner similar to Vibrance. 1.0 is neutral.
#define DPXSaturation 1.0 //[0.0 to 8.0] Adjust saturation of the effect. 1.0 is neutral.
#define RedC 0.3 //[0.6 to 0.2]
#define GreenC 0.3 //[0.6 to 0.2]
#define BlueC 0.3 //[0.6 to 0.2]
#define Blend 0.3 //[0.0 to 0.1] How strong the effect should be.
/ Lift Gamma Gain settings /
#define RGB_Lift float3(1.005, 1.005, 0.982) //[1.000 to 2.000] Adjust shadows for Red, Green and Blue
#define RGB_Gamma float3(1.000, 1.000, 0.987) //[1.000 to 2.000] Adjust midtones for Red, Green and Blue
#define RGB_Gain float3(0.987, 0.993, 0.999) //[1.000 to 2.000] Adjust highlights for Red, Green and Blue
/ Tonemap settings /
#define Gamma 1.08 //[0.00 to 2.00] Adjust midtones
#define Exposure -0.05 //[-1.00 to 1.00] Adjust exposure
#define Saturation 0.0 //[-1.00 to 1.00] Adjust saturation
#define Bleach 0.12 //[0.00 to 1.00] Brightens the shadows and fades the colors
#define Defog 0.011 //[0.00 to 1.00] How much of the color tint to remove
#define FogColor float3(0.00, 0.80, 0.00) //[0.00 to 1.00, 0.00 to 1.00, 0.00 to 1.00] What color to remove - default is blue
/ Vibrance settings /
#define Vibrance 0.15 //[-1.0 to 1.0] Intelligently saturates (or desaturates if you use negative values) the pixels depending on their original saturation.
/ Curves settings /
#define Curves_contrast 0.30 //[-1.0 to 1.0] The amount of contrast you want
// -- Advanced curve settings --
#define Curves_formula 7 //[1|2|3|4|5|6|7] The constrast s-curve you want to use.
/ Sepia settings /
#define ColorTone float3(1.40, 1.10, 0.90) //[0.00 to 1.00, 0.00 to 1.00, 0.00 to 1.00] What color to tint the image
#define GreyPower 0.11 //[0.0 to 1.0] How much desaturate the image before tinting it
#define SepiaPower 0.58 //[0.0 to 1.0] How much to tint the image
/ Vignette settings /
#define VignetteRadius 1.00 //[-1.00 to 3.00] lower values = stronger radial effect from center
#define VignetteAmount -1.00 //[-2.00 to 1.00] Strength of black. -2.00 = Max Black, 1.00 = Max White.
#define VignetteSlope 8 //[1 to 16] How far away from the center the change should start to really grow strong (odd numbers cause a larger fps drop than even numbers)
#define VignetteCenter float2(0.500, 0.500) //[0.00 to 1.00] Center of effect.
/ Dither settings /
//No settings yet, beyond switching it on or off in the top section.
//Note that the checkerboard pattern used by Dither, makes an image harder to compress.
//This can make your screenshots and video recordings take up more space.
/ Splitscreen settings /
#define splitscreen_mode 3 //[1|2|3|4|5] 1 = Vertical 50/50 split, 2 = Vertical 25/50/25 split, 3 = Vertical 50/50 angled split, 4 = Horizontal 50/50 split, 5 = Horizontal 25/50/25 split
Version 1.4:
Better Sights 1.2 by Khenaz
Beverhund HUD mod compilation
Leechmongers attachement mod
KyodanXD Objective icon removal
object blinking removal by tom.solo
Wallhack removal by KyodanXD
http://rghost.net/42133851
Using the 0x080912F5 flag in Nvidia inspector gives me constant 60 fps with everything maxed out using 4xMSAA at 1920*1200.DX11
Game runs sweet.
So, I'm slowly getting through this, and now I'm up to the missions for that woman in the temple. Doing the first mission for her...
I am a little bored to be honest, I am exploring lots, but getting sick of it. It's just camp after camp after camp. I can't be bothered with any of the side bulletin board missions as they are exactly the same each time.
I'm just bored and I have not even made it to the second island yet!
Resized from 2560x1440
SweetFX is a must for all. One problem - DX11 cannot run SweetFX with NVIDIA cards :( DX9 looks mint though
I am enjoying this more and more. I liked FC2 and got pretty far. Enemies don't respawn and I love that you have to build up your weapon holsters, ammo pouches etc etc
9/10
Enemies certainly respawn outside the main missions. Not at specific locations, but while exploring I gave up in one location after seven jeeps, one after the other, turned up to get in the way while I was pushing my jet ski over a sand bar.
Somewhere on those islands is a little factory churning out jeeps and red shirted blokes who've been struggling for suicidal work since Star Trek finished.
