Brand new computer just stopped working
19 Aug 2012
Please help guys I just got my new computer a few hrs ago was running fine and then I hit the plug with my foot and it gave a small spark I noticed it then the computer turned off so I fixed the plug made sure all was secure and turned back on and it turned back on ok and all pages restored so I carried browsing then after a few minutes it turned off again and that was it it will not turn back on not what has possibly happened please tell me I haven't fried my motherboard :( please help guys thanks
Woah, that was a heck of a sentence..
Have you tried a different power cable or changed the fuse in your current one?
Also make sure you haven't knocked the switch on the back of the power supply.
Please help guys I just got my new computer a few hrs ago was running fine and then I hit the plug with my foot and it gave a small spark I noticed it then the computer turned off so I fixed the plug made sure all was secure and turned back on and it turned back on ok and all pages restored so....
I got to there before i needed to breathe. :)
Hey sorry about the lack of punctuality and yh I have tried diff power cables diff extension leads everything but no life and I don't have a switch on the back for power supply
It's an acer m3 desktop
If your satisfied that you have tested all mains supplies are ok ie plugs and sockets, I would ask for a RMA as the unit is still under warranty.
You could do the PSU test in my post (couple back) but this would need you to dismantle some of the system.
Edit: Can you any LED'S on the motherboard with the side off?
Hi sorry took soo long the psu is a delta electronics 250w we just found that out is that why it's not working anymore is the gpu too powerful and what has happened has it just blown my psu?
It was already opened to insert graphics card I think it was there mistake as I've no idea why a 250w would be in a 8gb ran system runnin a 3.6 CPU so I've just ordered a 600w corsair for 30 hopefully that will fix
