Hi all
My Sennheiser PC151 headphones have recently broken and need replacing. I bought them before I put together the PC I use now, so I thought this might be a good time to go up in sound quality. My PC setup runs on a ASROCK Z68 Extreme 4 motherboard which has the on-board Realtek ALC892 Audio Codec, supporting 7.1 channel audio. I tend to play a lot of MMOs and some FPS too, so positional sound is reasonably important to me. However I don't tend to listen to much music, so really I am focussed on the best I can put together for gaming purposes only.
I am not sure if my money is best spent on upgrading from the on-board sound to a dedicated sound card and a new headset to go with; or putting all available money into a good set of stereo headphones with analogue connecters to plug into the motherboard I have; or to just bypass the on-board option and go with a USB headset with its own surround soundcard built in.
Some conditions: I want a headset with a mic attached (so no audio focussed headphones requiring a seperate clip on mic); I also have to have a closed ear headset as I share the computer room with my wife who works from home. Total budget is probably £100 - £150.
Any advice as to which route to go down and suggestions of soundcard and/or headsets for the budget would be gratefully received.
Thanks.
Thanks.
