Hi,
Currently working on my first watercooling setup and my fittings arrived today.
they are alphacool 16/10 compression fittings from a competitor
anyway i have tried them out because it'smy first time with compression fittings. i find that if i tighten them enough to hold the tube in place they cut into the tube quite a lot. if i only do them medium finger tight then i can pull them out fairly easily, which kind of makes a mockery of using compression fittings in the first place.
overall i am dissapointed with the design of these fittings, but i want to know from more experienced users what i should be expecting with compression fittings in general.
the compression ring has a sharp 90 degree flange on it, and i was expecting a chamfered profile to it. sorry can't do pics at work, so explanation might be lacking
cheers for any advice
