Windows 8 Activation problem.
5 Mar 2007
Macclesfield
Hello,
I’ve updated my 3 PC’s and 2 others (friends) using the same method without any problems. However, the last one I have to do will not active? Has anyone phoned up Microsoft activation centre and actually spoke to anyone?
If so, what was the experience like?
Here is what I have done:
Install a legit Windows on a virtual PC.
Run the upgrade assistant from the legit Windows.
Cancelled the download of Windows 8.
Use a previously Downloaded Windows 8 (64bit).
This has worked flawlessly until now?
I had to reinstall windows 8 yesterday on my HTPC (new SSD). I forgot it was an upgrade license and just done a clean install. I couldn't activate as it said "this is an upgrade license blah blah blah"
I then stuck my win 8 usb stick back in, and done a reinstall, keeping all settings.
It then installed win 8 fine and activated perfectly.
Might work for you?
i had to format my laptop due to not being able to boot in win8. so i used the win8 dvd that i created on my desktop because the win8 dvd that i created on my laptop was in another room. so i did clean install (no previous windows installed) after win8 was finished it wouldn't activate, not even with the reg hack, so i got the win8 dvd that i created on my laptop and i did the same thing clean install (no previous windows installed) after win8 was finished it activated fine,
may help
if you cant get windows 8 to activate
Activate Windows 8 Pro Upgrade
Windows 8 users who noticed that the operating system can’t be activated after the installation may want to try the following workaround that worked to activate when installing Windows 7 using an upgrade on a clean PC.
• Open regedit by pressing Windows-q, entering regedit and selecting the result from the list of hits.
• Navigate to HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Setup/OOBE/
• Change MediaBootInstall from 1 to 0
• Go back to the start screen and enter cmd there.
• Right-click Command Prompt and select to run it as administrator.
• Type slmgr /rearm on the command line and hit enter.
• Reboot Windows now.
• Run the activation utility afterwards, enter your product key to activate Windows.
Cheers everyone, nice to know its no just me, will try a re-install (over the top) tomorrow and then the suggestion above if that doesn't work.
Thanks again.
may help
Thanks!
worked for me!
may help
This worked for me, cheers.
Going to keep this safe as may come in useful if i do a clean install in the future.
