Upgrade Time from MSI 5850
Sho
Sho
21 Sep 2006
Oldham
Right folks. Time for me to upgrade my graphic card.
I've had my Twin Fozr 5850 for 2 years and has done very well.
Budget will be £200 Max..!
Specs are:
3570k@ 3.8ghz
Z77X-D3H
Crucial M4 SSD 64gb
Corsair Low profile 8gb ram
Coolmaster Hyper 612S Cpu Cooler
Thanks.
Best bet is probably a cheapest good brand custom 7950 and then sell off the game bundles. It would still be a bit over £200, but considering the overclocking headroom, it's well worth the extra over the 7870.
Well i do intend top sell my 5850 on MM. so that will give me another 40quid.
So a 7950? Any other alternatives?
In that same price range I would have to say no.
The lowest spec wise Nvidia card I would go for is the GTX670 with a proper full size PCB and custom cooler (rather than the reference card with a dwarf PCB and rubbish blower cooler), but that would cost around £300+.
Cards around the same price as the 7950 is the GTX660Ti, it is generally slower, and comparing to 7950's 384-bit memory bus and GTX670 256-bit memory bus, it only has 192-bit memory bus - which quite frankly shouldn't belong in the £200+ price bracket.
Fair enough.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-148-MS&tool=3
Take it that, will be the best card i can buy for my budget then? If so then, so be it.
How much of a increase will it be from mt Msi 5850?
+1
You should be able to comfortably reach 1100 MHz on the core as well for an even bigger boost. Will only require a tiny bit extra voltage as well on most cards and will still be pretty quiet. :)
Right then it is the card that i'll be getting.
I recently upgraded from a 5850 to a 7950 also. I was debating with going with a 7850, but I'm so glad that I spent that little extra and went with the better option, games run flawlessly, it's like playing on a brand new build all over again.
