- 27 Feb 2012
You'll need to put the 240 on front, with a big PSU like the 1200i it leaves next to no room for the cables having it on the bottom.
Just make sure you get the thickests and fattest 240 and 360, at least you'll get your monies worth out of the case that way..loads of space to use.
You'll also need more coolant, 1l isn't enough for that much raddage and componets (mine used 1.5l)
On another subject, why are you getting a HDPVR? There's a new edition that's smaller and has HDMI rather than composite, there's also an Elgato what's small and sleek (very good for recording consolols as wel)
