and the cheapest 7970 is 60 quid less than the cheapest 680
As much as l am a fan of AMD you have set yourself a difficult task. the 670 is slightly slower than a 680 so hits the price performance sweet spot imo, however the 7970 is just as fast as a 680 and can be faster at higher res.
Thank you for all comment I going to buy 7970 one. I have to use nvidia 2 times in my life my old pc and laptop. Ati just one time. I think I like ATI
7950 as it's only 5% slower than a 7970 and £80 cheaper.
It is only 5% slower if you downclock a 7970.
All 7950s will do reference 7970 clocks.
It takes about 10 seconds to load up CCC, go to the performance section, enable overdrive and set the sliders to the right.
My 2 7950s run at 950 by default (they're overclocked/boost editions).
The 7970's can be overclocked too, likely higher than a 7950. So this 5% argument is simply misleading.
From the clocks people get on this forum....
The averages between the 7950 and 7970 are around 1150-1250 core...
I think Rusty had one of the bad 7950s and that still managed a 1150core...
The highest clocking 7950 on these forums are 1340 core.
They can both clock, to near similar "max" clocks, its all about the luck of the draw as always with the silicon lottery.
Exactly, it's always going to be luck of the draw with the 7970 having a 125MHz head start before we even reach the 5% differential. The 7950 has a better price to performance ratio, I completely agree, but to unequivocally say there is only a 5% difference is simply not true.
