Today Only Deals! Save up to £44!!
Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black @ £149.99 inc VAT
The ASUS VN series features compact dimensions- this 23.6” display has a super narrow bezel less than 1cm thick, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN247H is also VESA wall mount compatible, and has the capabilities to be a stunning multi-screen solution.
VN247H leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including dual HDMI and D-sub inputs. An Ultra-fast 1ms gray-to-gray response time and trace free technology deliver realistic moving visuals and a blur-free multimedia experience. With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 250cd/m² brightness, the VN247H enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
VN247H comes with rich connectivity including Dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey. ASUS includes its exclusive QuickFit Virtual Scale feature with the VN247H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
Features:-
- Ideal for a multi-screen solution with a super narrow frame
- Best for work and play with Full HD 1080p visual quality and rich connectivity including dual HDMI and D-sub inputs
- Ultra-fast 1ms (gray-to-gray) response time for amazingly blur-free multimedia experience
Specification:-
- Panel Size: Wide Screen 23.6"(59.9cm) 16:9
- True Resolution: 1920x1080
- Full HD 1080P: Yes (support 1080i/p by 1:1)
- Pixel Pitch: 0.272mm
- Brightness(Max): 250cd/m
- ASUS Smart Contrast Ratio (ASCR): 80000000:1
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 1ms SUPER-FAST Response time
- Display Colors: 16.7M
- Signal Input: 2x HDMI & 1x D-Sub (DVI-D Supported via HDMI-to-DVI cable)
- Stereo Speakers: 2W x2 Stereo RMS
- VESA: 100x100mm
- Kensington Lock: Yes
- Phys. Dimension with Stand(WxHxD): 548.6x394.9x194.2mm
- Weight: 3.7kg
- Warranty: 3yr
Only £149.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (PVI38G213C1K) @ £35.99 inc VAT
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-17000 (2133MHz)
- Low Latency (11-11-11-27)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
Only £35.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- VESA: 100x100mm
- Weight: 3.7kg
- Warranty: 3yr
ORDER NOW
Features:-
- XMP Ready
- RoHS Compliant
- Lifetime Warranty
ORDER NOW
