**Today Only 12/12/2012** DGM IPS-2701WPH 27" LED Professional Monitor & Patriot Intel Extreme Maste
22 Aug 2010
Christmas is less than 13 days away and there is still chance to get some awesome presents for either a loved one.... or just yourself!
I need to start my Christmas shopping soon! But we can help you do yours.
DGM IPS-2701WPH 27" LED Widescreen Professional Monitor - Black @ £299.99 inc VAT
The IPS-2701WPH is DGM's new WQHD resolution monitor built around LED backlight LG IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The DGM IPS-2701WPH features the same high resolution LED LG IPS panel found in the Apple Cinema Displays. Video content bypasses scalers making the DGM IPS-2701WPH ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- Panel Size: 27" Diagonal IPS Panel
- Aspect Ratio: 16:9
- Resolution: 2560 x 1440 (WQHD)
- Pixel Pitch: 0.2331 mm
- Display Colors: 16.7M
- Brightness (cd/m2): 350cd/m2
- Contrast Ratio (Typ.): 1000:1
- Dynamic Contrast Ratio (Typ.): 80,000
- Response time (ms): 6ms
- Viewing Angle, H/V: 178 degree(H) / 178 degree(V)
- Input Signal: HDMI (Max resolution on HDMI is 1920x1080), Dual Link DVI-D, DP (Display Port), VGA (D-sub 15pin)
- HDCP Support: YES
- Internal Speaker: Built-in Stereo Speakers
- Wall Mount: VESA 100 x 100 mm
- Net / Gross Weight: 7.6 / 10.3 Kg
- Monitor Dimension (W*H*D mm): 645 × 487 × 172 mm
- Carton Dimension (W*H*D mm): 720 × 510 × 130 mm
- 3yr Warranty return to base with OcUK
Only £299.99 inc VAT.
ORDER NOW
Patriot Intel Extreme Masters 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz Dual Channel Kit (PVI316G186C0K) @ £59.99 inc VAT
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-14900 (1866MHz)
- Low Latency (10-10-10-27)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
Only £59.99 inc VAT.
ORDER NOW
good lets see 1440p and 1600p brought to the masses. Too long have we been stuck with most gamers happy with 1080p.
Right, everyone that was bitchin about missing the deal last time around, lets see you put your money where your mouth is.... its back at £299!!!! :)
These DGM 27" are fab. I love mine! Only one niggle for me is the stand being flimsy but I can live with that.
Bagged me some of the memory.....would have liked to be able to order 2 of them, but limited to one per customer.....oh well
The annoying thing about working 40+ hours a week, the doley bums get to grab great deals... lol. Too busy to go on internet in work time, I would get shot. :(
Demons UK said:
Cool bro, send this message via carrier pigeon? :D
Only work 8 minute walk from where I work, so go home for lunch. :)
Damn screens already sold out this morning lol. :(
