Hi I posted this in another thread but was told to make my own thread.
I've been reading up on watercooling for a few months now (And this forum for around a year but only just joined) and I think I'm finally ready to take the plunge, these are my specs.
Corsair 600T se white
Asus P8Z77-V PRO
i5 3570k @ 4.4GHZ
Corsair Memory Vengeance Low Profile Blue 2x4GB
Asus d2x
Asus directcu ii 670 2GB
Be quite dark pro 10 850W
Now I know the 600T isn't ideal for watercooling but I love this case and have added a sound dampening kit to it. I'm not afraid to use a dremel either and have seen on another site (think it was overclock3d) that you can fit a rad with a tiny bit of modding, I think it was the XSPC EX360. I'm hoping it would fit and if anyone here has done it, I know I'd then have to put the fans in the grill like with the H100i. I want to but the Overclockers V12 set and add this water block.
http://www.overclockers.co.uk/showproduct.php?prodid=WC-297-EK&groupid=962&catid=1520&subcat=2328
Would one 360 rad be enough to cool the 3570k and the 670 with low noise? as I don't really want to add a 200mm rad at the front. I might be willing to buy a better case for watercooling but all the ones I've looked at are too square and ugly at £150-£200 mark. I have a red NZXT phantom in the loft but it felt cheap to me and a bit loud. I do like the NZXT Switch 810 so could get that but then would need to buy another soundproofing kit.
Any help or advice would be really appreciated.
Asus P8Z77-V PRO
i5 3570k @ 4.4GHZ
Asus d2x
