Bargain-tastic Z77 board and free cooler? Yes please!!
20 Jul 2009
The bleak North East arm pit of Britain
OcUK has teamed up with MSI to bring you the best value cooler and motherboard bundle around. You may have seen a few deals around with some cheap cooler that comes with a board but at OcUK we are different. Why offer the same when we can offer better? ;)
Bring on the MSI Z77A-G43 / Alpenföhn Civetta Bundle!
MSI Z77A-G43 Intel Z77 (Socket 1155) DDR3 Motherboard - FREE Alpenföhn Civetta Cooler!! @ £79.99 inc VAT
FREE Alpenföhn Civetta with every Z77A-G43 purchase!!!
Specifications
- Supports 3rd Gen Intel Core i7 / Core i5 / Core i3 / Pentium / Celeron for LGA1155 Socket
- Intel Z77 Chipset
- 4 DIMM support for DDR3 1066 / 1333 / 1600 / 1866 / 2133 / 2400 / 2677 up to 32GB Max
- Intel HD Graphics 2500/4000 with integrated HDMI / DVI / DSUB ports
- 8 Channel (7.1) HD Audiop with THX TruStudio Pro
- Gigabit LAN
- 4x SATA 3Gb/s (Intel) With RAID Support
- 2x SATA 6Gb/s (Intel) With RAID Support
- 4x USB 3.0 (2 external / 2 Internal)
- 10x USB 2.0 (4 external / 6 Internal)
- 1x PCI-E 3.0 x16 slots
- 1x PCI-E 2.0 x16 slot
- 2x PCI-E x1 slots
- 3x PCI slots
- Now with Three Year Warranty
Only £79.99 inc VAT.
ORDER NOW
Im interested in knowing why you did this on the voltage locked motherboard?
Not everyone wants a crazy PC but they still want speed, reliability and the feature set offered by Z77.
Add this board and Cooler to an i5 3400 or similar and you have heaps of performance without breaking the bank.
The surely if you are buying a non-K chip you'd be looking at using the stock cooler and a H77 board :)
Just a suggestion but maybe put it on one of the unlocked boards like the much specc'd D3H?
Even a cheap aftermarket cooler is better than the stock cooler.
Isn't that basically why the H77 exists?
Essentially yes but instead of just swapping out the CPU when you want a little more performance you need to swap the board out too. £79.99 with an £13 cooler leaves the board value at a minimum of £67, theres very few full ATX H77 boards and those that are are either of similar value or more money so its win win for the customer to get them into gaming a little cheaper whilst money may be tight.
Indeed :)
