Adding an HIS IceQ boost 7950 with a GIgabyte 7950
14 Jan 2010
Essex
How would the clocks on the Ice Q react if I put one with an overclocked Gigabyte Windforce.
Would the Boost clocks automatically be matched to the overclocks of the Gigabyte settings or would the boost function interfere?
Or would both cards just default to the lowest clock speeds of one of the cards
Or are they just not compatible because one is boost and one is not?
Thanks for any help
both cards just default to the lowest clock speeds of one of the cards, unless over clocked to the same level.
Definately use the HIS as GPU1, the design of the shroud suits more enclosed spaces in comparison with the WF.
The cards each run at their own speed.
CrossFire has worked like that for as long as I can remember.
You can always overclock and match the speeds if you wish.
