metro 2033 physics.dll issue
C:\Program Files (x86)\Steam\steamapps\common\metro 2033\install go here then run the physics install as admin from that folder ,worked for me
Yup, the above method should sort your problem out, i vaguely remember the same thing happening to me a while back lol :)
it didnt work, it tried to uninstall physics but when i tried to load the game back up it came up with the same issue.
ive deleted the entire game and im re downloading it to try again. stoopid computers
Had that problem before, i can't remember what i did to fix it though, i did some googling to find the solution.
Edit: I think i downloaded the above file and put it into the Metro folder.
