- 11 Dec 2005
- Cheshire
We have launched a new "NANO" mini ITX bundle featuring the awesome AMD FM2 platform, with a choice of AMD APUs you can select the perfect APU for your application. Delivering fantastic performance with a combo of low power consumption, fast clock speeds and on board graphics.
We also have 2 new Sapphire mini PC's, just select your operating system and you are ready to go! A discreet system perfect for the home or office or even as a media home theatre PC!
Nano A75 AMD A4-5300 3.40GHz Mini ITX DDR3 Bundle - Dual Core @ £148.97 inc VAT
Designed by experts the "NANO A75 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "NANO A75 Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 8GB of Dual Channel DDR3 memory delivers fast load times
- Power saving processing for superior computing performance
- Fantastic onboard graphics capability
Bundle Specification
- CPU: AMD A4-5300 3.40GHz Dual Core APU (Upgrade options available)
- Motherboard: Asrock FM2A75M-ITX (Socket FM2) DDR3 Motherboard
- RAM: TeamGroup Elite 8GB DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
- Full 24 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow 7 working days for your system to be built and configured. This may take longer during busier periods.
Only £148.97 inc VAT.
ORDER NOW
Sapphire EDGE VS4 AMD Trinity A4 1.90GHz Dual Core DDR3 Mini PC @ £299.99 inc VAT
SAPPHIRE EDGE VS series is a new family of mini-PCs based on the latest Accelerated Processing Unit (APU) technology from AMD, codenamed Trinity. It delivers fantastic performance and stunning graphics in a small format for a wide range of applications. At home, the compact, beautiful design can be sited anywhere, replacing older bulky PCs – yet it will breeze through almost any task. For the business user, its super-compact and sleek design releases valuable desk or floor space, yet it runs all standard Microsoft Office and other productivity applications efficiently. The SAPPHIRE VS series is a revolution even for gamers. It supports all the latest games titles, with more and more being optimized for this technology. The internal Radeon HD graphics engine delivers superb graphics rendering for game play or video streaming.
Specification:
- CPU: AMD APU A4 1.9GHz Dual Core
- Memory: 2 x 2GB DDR3 So-DIMM
- Storage: 320 GB SATA 2.5'' Hard Driver
- Graphics: AMD RadeonTM HD7400G
- LAN: 10/100/1000 Mbps Built-in Ethernet
- Wireless: 802.11b/g/n Built-in Wireless Network
Built-in Bluetooth 3.0
- I/O: 1 x Mini Display Port
1 x HDMI Port
1 x RJ-45 Gigabit Lan
4 x USB 2.0 Port
1 x Audio-in
1 x Line-out
2 x USB 3.0 Port
1 x Optical SPDIF
1 x SD Card Reader
- Power: 65 W AC 100~240V 50/60Hz, DC 19V~3.42A
- Dimensions: 19.75*18.25*3.16 cm (L / W / H)
- Weight: 660 g net weight
- Operating System: Pre-installed Free DOS
Support Windows® 8 / 7 / Vista
- Accessory: 1 x HDMI cable
1 x HDMI to DVI adapter
1 x Quick Installation Guide (QIG)
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
1 x Driver CD
1 x Optical SPDIF cable
1 x VESA Mount
Only £299.99 inc VAT.
ORDER NOW
Sapphire EDGE VS8 AMD Trinity A8 1.60GHz Quad Core DDR3 Mini PC @ £399.95 inc VAT
Specification:
- CPU: AMD APU A8 1.6GHz Quad Core
- Storage: 500 GB SATA 2.5'' Hard Driver
- Graphics: AMD RadeonTM HD7600G
1 x HDMI Port
4 x USB 2.0 Port
1 x Audio-in
1 x Line-out
2 x USB 3.0 Port
1 x Optical SPDIF
1 x SD Card Reader
- Power: 0 W AC 100~240V 50/60Hz, DC 19V~3.42A
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
1 x Driver CD
1 x VESA Mount
Only £399.95 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Specification:
1 x HDMI Port
4 x USB 2.0 Port
1 x Audio-in
1 x Line-out
2 x USB 3.0 Port
1 x Optical SPDIF
1 x SD Card Reader
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
1 x Driver CD
1 x VESA Mount
ORDER NOW
Specification:
1 x HDMI Port
4 x USB 2.0 Port
1 x Audio-in
1 x Line-out
2 x USB 3.0 Port
1 x Optical SPDIF
1 x SD Card Reader
1 x Chassis Stand
1 x Power cord
1 x Power Adapter
1 x Driver CD
1 x VESA Mount
ORDER NOW
