** OCUK TECH LABS - PERFORMANCE WATERCOOLING KITS - 2013 REFRESH **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
Today we have uploaded finalised changes to our best selling Watercooling Kits
OcUK Tech Labs kits are the best hardware picked by us to meet the following important criteria:
  • Ultimate Price:Performance balance
  • High Quality Components
  • Benchmark Proven results
  • Market Leading components
  • Incredible Aesthetics
Each component we choose is based on reliability.
We check the runrate, popularity and return rate for each part of our kits to ensure your watercooling kit is hassle free and runs perfectly.
designed to fit in small, mid and large tower cases, the kits are ALL upgradeable. Add a VGA card to the V12 kit easily or include more radiators into the baseline V6 and V8 kits to increase your cooling capacity.
Even a beginner can install one of our kits, Check out our guide Here
Each of our kits now ships with the Award Winning XSPC Raystorm as the default CPU waterblock. This block is an Intel only waterblock but you can swap it to the AMD version of the block if you like [I will be adding this feature in the next few days]
We fully endorse the use of Mayhems products in all of our watercooling kits and each kit is offered with the whole range of Mayhems specialist fluids which allows you to customise the aesthetics of your system.
To Celebrate the relaunch of the Tech Labs watercooling kits, we have put each kit at a new price point making them even better value for money!
There are some sweet savings to be made on buying your kit at OcUK!
The V6 Range at OcUK Tech Labs is the first step on the ladder to custom cooling solutions,
but there is no budget hardware in this kit.
This is tier one hardware - 'Entry Level' has never been so hardcore!
OcUK Tech Lab - V6 Watercooling Kit 120 Intel @ £130.00 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
OcUK have stepped in and solved this problem. With each OcUK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike
Component List:
1X XSPC EX120 120mm Radiator
The latest radiator from XSPC, outstanding performance and superb quality
1X XSPC X2O 750 Dual 5.25” Bay Reservoir Pump V4
A clever space saving solution that allows you to see your coolant level from your drive bays
1X XSPC Raystorm
The most advanced high performance CPU waterblock on the market. LED customisation and astounding flow rates make this perfect.
1X Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin Fan
The most recognised performance fan for watercooling radiators.
1X Mayhems Coolant
Pick your own coolant that suits your taste and style
1X XSPC 7/16" ID [16/11mm] Clear
High quality watercooling tubing with a superb bend radius
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Silver Finish
Trusted and reliable fittings. These fittings ensure a tight grip on your tubing for long lasting reliability.
Was £134.99 Inc. VAT
Only £130.00 inc VAT.
ORDER NOW
V8 Kits strike the balance between entry level and high end.
Our V8 kit is suited to the user who wants ultimate CPU cooling or is potentially looking to include a VGA card into their loop at a later date.
[this would require additional radiators depending on application]
OcUK Tech Lab - V8 Watercooling Kit 240 Intel @ £184.98 inc VAT
Ideal for first time watercooling enthusiasts and seasoned veterans alike.
Component List:
1X XSPC EX240 120mm Radiator
Ultra high air flow and innovative built in shroud design offers uncompromised performance that is second to none.
1X XSPC Raystorm Intel
2X Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin Fans
The most recognised performance fans for watercooling radiators.
1X Mayhems Coolant
6X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shining Silver Finish
Was £189.98 Inc. VAT
Only £184.98 inc VAT.
ORDER NOW
V12, The cream of the crop and the very best there is.
Our V12 Kit merges uncompromising cooling performance with futureproof upgradeability.
OcUK Tech Lab - V12 Watercooling Kit 360 Intel @ £249.99 inc VAT
Component List:
1X XSPC EX360 120mm Radiator - Black
Offering superb performance, build quality and value the XSPC EX range of radiators are the obvious choice for high end watercooled systems.
1X XSPC D5 Dual Bay Reservoir/Pump Combo
The worlds best watercooling pump mounted to a high performance, stylish reservior. This is the ultimate choice for a tidy system with easy to fit and fill internals.
3X Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin Fans
1X Mayhems Coolant
2X XSPC 7/16" ID [16/11mm] Clear
8X OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish
Was £269.98 Inc. VAT
Only £249.99 inc VAT.
ORDER NOW
good timing then!
is there any questions you have? I can answer them right here :)
Only real question is, as I'm looking at custom watercooling, if I just get 1/2" barbs and some 7/16" tubing I can just heat up the ends with water and they will go on fine and have no leaks? Or should I put some cable ties on just to be safe?
Thats what i had on mine, just put the ends in hot water for 10-15 sec and then they slip on fine. I did not have any cabe tides on as i they were fine but u can if want to feel safe.
the way we design it is that it can be used with barbs and no clips, but cable ties work too.
the tubing is very tight on the barbs but it cant hurt if you want the reassurance.
h100 testing vs the v6 kit
3960x @ 4.5GHz @ 1.35v
H100i on max fan 81'c
H100i on medium fan 84'c
H100i on low fan 88'c
OcUK V6 on max fan 74'c
OcUK V6 on medium fan 78'c
OcUK V6 on low fan 82'c
gonna try to do testing vs the v8 and v12 kits and maybe the upcoming kit i plan on doing
Does the XSPC D5 Dual Bay Reservoir/Pump Combo create more noise than say a seperate pump and resevoir?
I get the impression from aricles I've read they are.
the kits use the new v4 pump, which has a much quieter operating sound than the previous models.
im planning on making 140mm versions of the kits soon.
Awesome, been looking forward to the NZXT closed loops. However, after it taking me 8 months to get a replacement fan controller from them for a Phantom 410 I would prefer to avoid them at any chance I get.
Been thinking about going water cooling, never done it before.
Which kit would be best for my case CM 690 II Adv, specs say "Accommodates 120 x 240 mm radiator inside the top and bottom".
The v8 and v12 will be better. Hard to say on the v6 kits as the krakens are not out yet.
The v8 kit would be ideal for that case. You could potentially buy another 240mm rad if you wanted a big loop and a vga card in the loop at a later date
Cooling CPU and 2 GPUs here. Which kit (if any) would be suitable?
Depends on what cpu and gpus they are.
If you have a low tdp cpu and fIrly cool running gpus then I would say that the v12 would be a solid starting point.
If you have a pair of 680 cards and a 2011 cpu for example, you may want to include another radiator. A 240 would be the minimum.
Depends what you would be cooling.
Is the price for the V12 £249.99 inc VAT
When I click on the link it says £250 but that is the 'This week only' Price. And it is normally £269.98.
Just wondering because It will be after xmas when I may purchase.
Cheers.
its on This week only at the moment which has messed up the pricing.
it will be a little more expensive next week but not by much,.
