gigabyte wf3 appreciation society thoughts,issues,and overclocks!
Good to hear Chris, well mines on its way now ,cant wait, it be going into my 2nd pc thats beside my main pc , i will oc mine to a hd7970 no more than that tomorrow.
my main pc is water cooled ,but my 2nd pc is not
This 7950 WF3 has highlighted one issue for me, my 10 year old Thermaltake Lanfire case needs replacing as the air flow sucks!
Sleeping Dogs got the GPU upto 70c last night at 1150 1.218v and my CPU temp went up 10c higher than i have ever seen it before!
This card is literally baking my CPU:D
Chips for dinner....
what memory clocks and core are people running on stock volts for 24/7
and
memory clocks and core clocks and voltage with voltage tweeks for 24/7
my windforce 3x runs at 1200/1800mhz 1256mv core 1649mem v
never gets above 58'c with a custom fan profile
really need to change my sig, run at 4.9ghz aswell now :)
wow you have that memory running mega fast! what are your vrm temps? do you have your fan on quite hight to get those temps at that voltage? surprised thats safe tbh
vrm temps are hitting 67'c in bf3
are you on air or water? you must have your fan turned up pretty high or?
Think i have fixed the BSOD's i was having when leaving the computer idle for several hours, setting power options to never turn off the monitors.
i think im getting this now i leave the pc awhile come back and it wont come out of sleep mode!pc still running but wont start up the monitors and let me use the pc have to turn the whole thing off via the psu power switch!
how come this happens?
Yep id either come back and the monitors would be on but the screens would be blank or come back to a BSOD, either way a hard reboot was required to get it back.
Had this same issue with my 7850 and 7950.
well after a bit of fiddeling with volts and fan profiles i now have the card running 1150/1450 @1.225v core temp max 58c and vrm's max 64vrm 1 and 66c vrm2 (playing metro 2033 everything maxed)
pretty happy with those temps tbh
any point in pushing for higher clocks? will i realistically see any performance gains in game pushing any further?
I may as well post in here, their are new versions of the Gigabyte 7950 WF3 with BIOS - FZ0 - Manufacture date: November 2012 - See this thread >> http://forums.overclockers.co.uk/showthread.php?t=18469510
It's basically a GHz version of the 7950, with the following default clocks @ 1.25v - Voltage is locked - unless you use 'Force Constant Voltage' in MSI Afterburner, doing so loses powerplay - power saving features in desktop.
Mine did 1150MHz on the core @ 1.25v, anything higher would result in artifacts in Heaven 3.0, someone elses did 1200MHz @ 1.25v le silicon lottery.
