- 17 Apr 2010
How will Haswell compare with Trinity?
Probably for that kind of work, especially if I wanted value for money. If I was going to run it 24/7 I probably wouldn't though as they're a fair bit less power efficient than the intel alternative.
They do, but not for consumers. A pair of 6344s come out around the same price as the 3930K, but give you 24 cores. As above, you can think of this as similar to 12 cores in intel's architecture. In a memory intensive, multithreaded environment, I expect these would be higher performance.
http://www.servethehome.com/amd-opteron-6300-lineup-intel-xeon-threat/
The real attraction of these chips is in HPC though, as you can stick 4 of these 16-core chips in a mobo with practically as much memory as you want (up to 512 GB) and have a crunching beast. More, lower clock speed cores give you a really power efficient machine too.
AMDs problem is they have nothing to match the hex core i7s, if they ever did find a CPU to match them I don't think intel would have any problem churning out hex cores at i5 prices.
so yeah, Intel are that good but only because Advanced Micro Devices never really had a chance anyway, and the blame is pretty much on their shoulders as well.
Actually it's depended on the games being play. If you look at random single player benches there's usually not much difference between the two due to GPU bottleneck...but if you throw in online gaming performance, poor CPU core counts scaling, 120Hz monitor (without the 60Hz bottleneck) with high-end SLI/CF graphic setup into the mix, Intel would pull away with quite a big margin.High end intel's are ahead yes, but for general gaming an 8350 can match 3570K's
It wasn't always a 2 horse race though. I was looking at this list of processors the other day http://www.cpu-world.com/CPUs/CPU.html and it's surprising just how much competition there was in the '80s and '90s.
But generally speaking...for single player games that are using 4 or more cores and only on a single GPU graphic card, there's probably not gonna be any noticable difference between the two CPU. But I think Intel would still be a bit more power efficient if both CPUs were to deliver the same gaming performance.
Also to be honest, the FX8320 (the £130 AMD CPU OP's refering to) ain't exactly hugely cheaper than the i5 3570K...and then I think people have already reported that the 8320 seem to not overclock as well as the more expensive 8350.
also what some just don't get is the amd 8350 is priced lower for a reason its slower ! they are priced to compete with relevant counterparts. the 3570k isnt its rival. the amd 8350 is below that and has been show in many articles. basically its about 10-15 percent slower in games no matter what way you cut it. this is why the price reflects this. benchmark as many video encoding runs as you want it is slower![]()
that's why i put it
Well, it's not just encoding the FX8350 is faster.
In raw performance, if software wasn't the limiting factor in many of the situations the FX8350 loses, it would be the faster CPU, that said, Intel knows the situation with software, and that's why their CPU's are how they are with CPU's like the 3570k, can't see it paining Intel to release some mainstream 6 threaded hex core, but they don't need to.
its like trying to argue about physics.
