New Gaming PC for 2013
4 Dec 2011
Hi guys,
I'm looking to upgrade again. The main use for the PC will be gaming but also needs to handle After Effects / Sony Vegas / Photoshop. The main games will be RTS but if it can handle FPS that would be great aswell.
Here is my proposed spec. Please comment and feedback. All constructive criticism / suggestions welcome. :)
Also, this basket is the maximum I am able to spend (+£20/30)
MY BASKET
1 x Intel Core i7-3770K 3.50GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £259.99
1 x ASUS GeForce GTX 660TI Direct CU II 2048MB GDDR5 PCI-Express Graphics Card £239.99
1 x Asus Z77 Maximus V Gene Intel Z77 (Socket 1155) DDR3 Motherboard £154.99
1 x Corsair Vengeance RED 16GB (4x4GB) DDR3 PC3-17100C11 2133MHz Dual/Quad Channel Kit £99.95
1 x Antec High Current Gamer 620W '80 Plus Bronze' Power Supply £79.99
1 x Samsung 250GB SSD 840 SATA 6Gb/s Basic £159.98
1 x CM Storm Enforcer Gaming Case - Black £74.99
1 x Arctic Cooling Freezer 13 Pro Extreme Performance CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) £26.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £1128.38 (includes shipping : £13.75).
Many Thanks,
Javo :)
sorry to bring this back from the dead - but both recommendations picked 1600MHz RAM instead of by inital 2133MHz. My question is that does the 2133MHz RAM not give a good enough performance boost for the price or do I not need it etc.?
also is 2x8GB better than 4x4GB?
thanks & merry christmas :D
I believe the price difference between the two isn't worth it when considering the small increase in speed. Using fewer/larger capacity modules of ram puts less stress on the memory controller and also helps space when installing the cpu cooler.
(no expert but I believe that's the reasoning, I'm sure someone will chip in, if incorrect)
You may see 1 or 2 fps more in games with the RAM, but that's assuming you already get like 80-90 fps, totally not worth it!
