Ok guys, just in the process of buying bits for a new system I'm putting together. The spec is listed below, however, I'm a little confused in Graphics Cards and PSUs.
I'm going to be using Photoshop and BF3, but would like some future proofing in there as I don't wanna have to upgrade in the next 6 months! Could you guys suggest a Graphics Card that would last for any new games that are coming out for the next 6 months or so on fairly high res'?
Also, I'm a little confused with PSU's and what connectors are needed/included in new ones. I have a decent PSU but I'm not sure if it'll work with my new rig (Will check later what it exactly is!)
Spec:
i5-3750k
Gigabyte Z68AP-D3
8GB G.Skill Ripjaws-X F3-12800CL9D
Corsair Force 3 120GB HDD
Its all going in an ANTEC ONE MIDI case. Also, what else am I missing?
Thanks in advance!
Regards,
Spec:
i5-3750k
Gigabyte Z68AP-D3
Thanks in advance!
Regards,
