**Today Only 18/12/2012** Aerocool Strike-X X-Pad Mousepad & TT eSports Challenger Gamers Keyboard
22 Aug 2010
Today Only Deals!
Aerocool Strike-X X-Pad Mousepad @ £6.98 inc VAT
With this Gaming Mouse Surface from the specialists Aerocool, you have control over what happens on the screen, whether for work or play.
It offers a 400 x 200mm surface wide enough space for mouse movements and feels comfortable, thanks to the natural rubber.
With the form of an indicated "X" and the eye-catching design on the front and an anti-slip coating on the back is the three-millimeter-high Aerocool Strike-X X-Pad is the ideal complement for any demanding PC users.
- Dimensions: 400 x 3 x 280 mm (W x H x D)
- Material: Natural Rubber
- Color: Black / Red / Yellow
Only £6.98 inc VAT.
ORDER NOW
TT eSports Challenger Gamers Keyboard @ £21.98 inc VAT
This keyboard offers a unique cooling solution for your hands when the heat of the battle takes its toll on you. Allowing you to game under many different conditons you will be razor sharp at all times.
- Interface: USB
- Operational systems: WindowsR 7/Vista/XP
- Number of Macro keys: 6
- Number of Multimedia keys: 7
- 2.0 USB port: 1
- Switch lifecycle: 10 Millions
- Cable length: 2m
- Body dimension (LxWxH): 480x 205.5x 25mm
- Fan Speed: 6,000 RPM(±15%)
- Max. airflow:2.7CFM
- Noise level:21.7dB
- Rate voltage: DC 5.0V
- Life expectancy: 50,000 HRS
- Body dimension (LxWxH): 30x30x10mm
Only £21.98 inc VAT.
ORDER NOW
