**Today Only 17/12/2012** Seasonic G series 650w '80 Plus Gold' PSU & Thermaltake Level 10 M 8200 DP
22 Aug 2010
Today Only Deals!! Make sure you order in-time for Christmas :)
Seasonic G series 650w '80 Plus Gold' Modular Power Supply @ £79.98 inc VAT
For the ultimate in low wattage, high quality PSU needs comes the Seasonic G Series PSU with 360 / 450 / 550 and 650w options these units are perfect for any HTPC or mid range gaming system.
- 80 Plug Gold Certified
- DC to DC Converter Design
- Tight Voltage Regulations (±3%)
- Smart and Silent Fan Control
- High Reliable Aluminum Electrolytic Capacitors
- Conductive Polymer Aluminum Solid Capacitors
- Detachable Modular Cables
- High Current Gold Plated Terminals
- 12cm Ball Bearing Cooling Fan
- Ultra Ventilation (honeycomb structure)
- Mulit GPU Technology Support
- Universale AC Input
- 5 Year Warranty
Only £79.98 inc VAT.
ORDER NOW
Thermaltake Level 10 M 8200 DPI Gaming Mouse - Black @ £77.99 inc VAT
Level 10 M Mouse is designed with open structure in between between top and base segments, and the space in between the mouse also serves to adjust the height and angle via steering axis, greatly enhance user comfort and convenience as well.
Level 10 M Mouse is a programmable gaming mouse capable of using the most comprehensive software application to customize settings based on gamer’s needs. Specifically, the Z key can be programed to switch up to 5 gaming profiles. Other features such as the polling rate and the 7 lighting-effect colors are also customizable through software, making Level 10 M Mouse a truly amazing mouse for pro-gaming and creative needs.
The body of the mouse has a adjustable height spring, and you can even adjust the mouse camber either way by 5 degrees.
Aluminum base is one of the toughest chemical materials with character of high resistance to corrosion, and commonly used in aerospace industry and architectural purpose. Level 10 M Mouse is designed with solid aluminum material to ensure both durability and tenaciousness are constantly experienced by the users over Level 10 M Mouse’s quality and long-lasting durable experience.
- DPI: 8200
- Sensor Type: Laser
- No. of Buttons: 7
- Game Genre: Memory Size
- No. of Macro Keys: 11
- No. of Game Profiles: 5
- Lighting Effect: Yes
- Pause-Break Effect: Yes
- Color Options: 7
- USB cable length: 1.8m
- Weight-In Design: No
- Graphical UI: Yes
- Industrial Rubber-Coating: Yes
- Weight: 185g
- Gold-Platted USB: Yes
- Dimension: 147 x 67.5 x 38.8 mm
Only £77.99 inc VAT.
ORDER NOW
what do you mean? You can order online till 9am tomorrow morning.
What I meant was that unless one went to OcUK's home page , One wouldn't have known that those two items were only available as web exclusives and as such, were not available to buy over the Phone, I was going to buy the PSU...but was unable to, It would be nice if it had said " web exclusive" , I don't "Shop Online" I only do it via the Phone :)
We would have honoured it via the phone, hell if you call up today, we will still honour it for you.
OK Ace thank you....the reason I'm going on about it lol is that about 10 days ago I was also going to buy a Graphics card upgrade that was on offer at the time...but when I called I was told " No sorry it's only available as a web exclusive and cant be bought via the phone , So I was wanting to clear that up ....so I am more informed in the future :)
