- 22 Jul 2010
- Kent
youa big boy
and i was only jk'ing, but for me i'd stick in a lower priced amd and or spec 4 gb of ram but would still go for a card, and change mobo to one that supported using onboard and card if using intel
It's all good bud. I know Bacon quite well, he knows I dont mind a bit of banter......as long as it helps inform the OP in the process.
If the OP has a HDTV he could consider using that and making a HTPC to rival the consoles. Having that £100 back in the budget will definately help the spec
