Man of Honour
- 21 Nov 2004
I am worried that I might need the same come my MOT + service on the 29th. My quote was £600 last time
To be absolutely clear op
You need 1 x each of the pads (front and back) - these are priced per axle i.e 1 x front 1 x rear, 4 pads in a box
2x front discs
2x rear discs
The discs will come in a box of two but you need to pay for 2 discs per axle if that makes sense, the site would probably flag up trying to purchase 1 nr disc anyway
I'd ask them if all 4 need doing first though, you might find the rears or fronts are fairly new in which case there's honestly little point in replacing unless you have issue with how the car stops at present
For what car?
It's a very simple task to diy provided you've got the right piston tool for the rear (even if not a tool is usually easily bodged if you know how)
For what car?
Me and a mate did the front brake pads (ferodo ds2500s) on my ep3 a few weeks ago for a track day.
It took us ages... Them bolts are done up tighter than a nuns you know what for a reason.
I'd rather pay £20 for someone else to do it.
A bigger bar would sort them in seconds, I've honestly never come across caliper bolts that were all that hard to.release, certainly none that a 12" bar didn't make short work of even on 20 year old motors (and I ain't Popeye)
