Today's deals! You can still get these in time for Christmas
Corsair Graphite 600T Midi Tower Case - Limited Edition White @ £129.98 inc VAT
The Graphite Series™ 600T makes it easy to build a world-class gaming system. With excellent cooling from the dual 200mm fans, eight PCI-E expansion slots to accommodate multiple graphics cards, and plenty of room for large, power-hungry components, the Graphite Series 600T can handle just about anything you can throw at it.
The Graphite Series 600T is a mid-tower in height, but inside it’s positively cavernous. Easily accommodate even the longest graphics cards in the industry due to the reconfigurable hard drive bays. The increased space behind the motherboard tray allows clean, uncluttered cable routing. Up to six hard drive caddies, each of which can accommodate SSDs and standard mechanical disks, sit below the four 5.25" tool-free optical drive bays. If that weren’t enough, you can remove the top panel 200mm fan and install a 240mm radiator and dual 120mm fans for a quick watercooling upgrade. The Special Edition White 600T also includes a new custom side panel with a cutout for a window (pre-installed) or included mesh insert with room for up to four 120mm fans for even more outrageous cooling!
Corsair innovated cable routing with the Obsidian Series™ cases, and the Graphite Series features the same ingenious design. Pre-cut holes in the motherboard tray with rubber grommets and plenty of room behind the motherboard to route cables for a clean, uncluttered interior. The optical drive bays are tool-free, the side panels easily detach with the built-in latch mechanisms, and the integrated fan controller allows you to choose between quiet operation or maximum cooling performance.
- Twin 200mm cooling fans with white LEDs for excellent cooling
- Side panel with cutout for window AND mesh with room for four 120mm fans - both included!
- Eight expansion slots provides you flexibility for multiple graphics card solutions
- Unique cable routing holes guarantees you a clean and clutter-free installation
- Integrated fan controller, for up to four fans, gives you the choice of noise vs. performance
- Tool-free optical drive installation makes building your system faster than ever
- CPU backplate cutout makes upgrading your CPU heatsink easy<br>
- 2.5” and 3.5” hard drive compatibility for up to 6 drives — straight out of the box!
- Two year warranty with Corsair’s world-class customer service and technical support
Only £129.98 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 680 WindForce 5x SOC 2048MB GDDR5 PCI-Express Graphics Card @ £399.95 inc VAT
The Gigabyte GeForce GTX 680 SOC also known as the WindForce 5x is a very impressive GTX 680 with a whopping five fans, a massive heatsink, vapour chamber and nine heatpipes. What this offers is upto 46% better performance for the same noise load as the stock cooler, its even quieter at idling, as only two if its five fans will be active. This cooler is massively over-engineered and will never struggle with the heat output a GTX 680 can output even at maximum OC potential. This Gigabyte SOC edition is simply un-rivalled when it comes to cooling performance.
Serious gamers require serious gear. That’s why we’ve developed the Super Overclock Series. All of the GPUs in these graphics cards have been cherry-picked for top performance, efficiency and reliability. Our innovative GPU Gauntlet™ Sorting selection process ensures that only the highest-performing GPU processors are used in these graphics cards. Coupled with our Ultra Durable VGA boards, users can rest assured that the Super Overclock Series graphics cards won’t let them down as they step onto the digital battleground.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- The power of 3-way NVIDIA SLI® technology
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1137MHz (GK104)
- Core Boost Clock: 1202MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2274MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 2x 8-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- Warranty: 3 Years
Only £399.95 inc VAT.
ORDER NOW
ORDER NOW
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
